Proper Nav System/HVAC behavior
My Nav screen seems to have a mind of its own. When I start the car, sometimes the Nav screen will return to its last displayed function, usually radio. Other times it goes to the select screen. If I hit the radio button, the station will appear but without the "ST" in the upper right hand corner (sounds the same to my uneducated ear). Same, although less frequently, with the HVAC controls. Usually goes to last setting, but sometimes goes back to a previous setting. I assume it all should go back to last setting, correct??? Simple software fix ( I probably have older version)? Thx
