Why a short-shifter? - BMW M5 Forum and M6 Forums
Old 28th February 2003, 22:02   #1
ELEVENS
Garage: '03 M5 LMB/LMB&Al
This is an obviously mis-informed question because I've never driven an M5 with a shortened shifter. But after driving my new beast for a couple of days, the stock shifter seems not too bad at all. And when cold (13 degrees F. this morning), I don't think I'd want to give up any leverage.
I guess my question goes out to the folks that have installed shifters. What were your motives or goals?
ELEVENS is offline   Reply With Quote
Old 28th February 2003, 22:11   #2
MIB
MIB's Avatar
Garage: 03 M5 Steel Grey/Petrol-LMB/Ti
Re: Why a short-shifter?
Hey Elevens,
Mines not installed yet, but I've driven both, with and without.
With the Rogue Engineering SSK & WSR, you don't give up leverage. Thats why I bought that one.
The Weighted Selector Rod counter Balances and makes for a nice smooth shift again.
Visit www.rogueengineering.com for a better explaination. After you enter the site,. Click on the Yellow Icon that says OCTANE SSK
///Mark 03 E39 M5 He's in Apples hands now. MIB
MIB is offline   Reply With Quote
Old 28th February 2003, 22:23   #3
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
I have the Rogue Octane kit with the WSR and I love it. The throw is reduced but it's not ridiculously reduced. Effort has not significantly increased and I don't get the vibration that some other shifters seem to have a problem with. The only time there is some notchy feeling is until the beast is warmed up on a morning where it was 15 or 20 degrees F.
I think the short shifter improves the driving experience. I don't know if I can put it any better than that...it may be something that you have to experience to fully get the idea. Do you have any buddies with an M5 with a short shifter that you could try out? It's one of those things that if you never tried it, you wouldn't know what you're missing, but after having it, it would be very difficult to go back to not having it. I feel the same way about my Valentine V1. It's hard to try a radar detector without the directional arrows and "bogey" counter after using the V1!
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline   Reply With Quote
Old 28th February 2003, 23:06   #4
chunpng
chunpng's Avatar
Garage: M5, silver/black
Bill,
The stock shifter is perfectly fine as is. I have my car for 22 months now, and still bone stock, except for a Dinan chip.
I once seriousely considered a short shifter and talked with Greg regarding his take on the subject. He told me that in stock form, the M5 shifter is probably 'shorter' and less sloppy than that in his 996tt. With this input, I was content with the M5 shifter until......
December 4, 2002, I bought a Miata with a short shifter. A REAL SHORT shifter (3"-4" total!!). The action is soooo precisce, every shift is just a tiny 'snick', and the lowered shift knob position induced a much sportier feel.
It's gotton to the point that now I feel the M5 shift knob is way too tall. It's not the shift action, just the hand position. So I'm tempted by a SSK just to lower the shift knob height. I'm sure eventually the shorter throw will feel great too.
Another point, I have enclosed garage both at home and at work, so I'd never have a real cold start, so cold-weather notchiness associated with the SSK should not be an issue for me.
I guess like Ray says, the SSK is something you need to experience to appreciate. A good parallel may be a garage door opener. I lived years without it, opening/closing the garage door manually. Then I got one, and wondered what was I thinking before.
CP
CP
00 Titanium Silver: 6/00-1/05 RIP
95 Black Metallic RUF BTR-2
07 Meteor Grey Cayman
chunpng is offline   Reply With Quote
Old 1st March 2003, 19:04   #5
Bart Carter
Bart Carter's Avatar
Garage: 2002 M5 Bluewater/Caramel
I find that the stock shifter is just fine.
I have a good feel for the gears, it doesn't vibrate, it doesn't have an excessive throw, it doesn't cost me any more money.
-Bart
2002 Bluewater/caramel
Any other car is a compromise
Bart Carter is offline   Reply With Quote
Old 1st March 2003, 19:18   #6
pmiranda
pmiranda's Avatar
Garage: 2002 LeMans Blue M5
Because I kept pulling the shift knob off iwhen I got in the Z3! The M5 throw was so ridiculously long compared to the (stock) Z3 that I kept pulling off the knob on the 1-2 shift. After installing the Rogue kit, it's very nice, but a little stiff in the morning, even though it's in a garage that never gets below 50F. I think I'll adjust it one notch longer.
pmiranda is offline   Reply With Quote
Old 1st March 2003, 19:19   #7
jmott
Garage: Silver M5
On mustangs, the short shifters had a neat feature called "positive stops". There were basically adjustable bolts that prevented you from shifting to far up or down.
So you can SLAM it from 1st to 2nd, or 2nd to 3rd without risk. I don't believe any M5 shifters have this feature. not to many gear slamming dragster M5s
a lot of aftermarket shifters will also have stiffer bushings and such to make things feel more "solid".
this not much of a performance reason to do it though.
and dealers love to find things just like shifters to blame for tranny problems.
jmott is offline   Reply With Quote
Old 1st March 2003, 20:06   #8
BostonRocket
BostonRocket's Avatar
If you have never driven a car with a really short throw shifter on it, you will never feel the need get a ssk. Once you try it though, you can never go back.
'Rocket
BostonRocket is offline   Reply With Quote
Old 1st March 2003, 21:14   #9
LSU1981
LSU1981's Avatar
Garage: 2000 M5 Avus Blue
.....I guess my question goes out to the folks that have installed shifters. What were your motives or goals?
Elevens,
I was looking for shorter, more precise throws -- got it with the AutoSolutions Kit. As a side benefit the wife does NOT like the SSK so never asks to drive the beast!
2000 M5 Avus Blue / LeMans Sport. (sold to MPRESIV, 9/04)
2002 M3 Carbon Black/black
2004 Sierra Denali
2008 335xi - on order
Gone - Shelby Cobra Roadster, 01 Carrera C2 Coupe, 00 M5
LSU1981 is offline   Reply With Quote
Old 2nd March 2003, 04:40   #10
MAVERICK
MAVERICK's Avatar
Garage: X
ELEVENS,
Trust me, you have to try it for yourself. Go and testdrive someone's car that has a shortshifter. Then, you will be enlightened.
"Friends don't let friends drive automatics!" -- Alpinadvl
MAVERICK is offline   Reply With Quote
Installed UUC short shifter this week mofo_knows E39 M5 and E52 Z8 Discussion 2 26th April 2003 15:38
New UUC short shifter for E39 M5 ALX Parts / Other For Sale or Wanted 1 6th November 2001 06:31
UUC short shifter fix installed steveB E39 M5 and E52 Z8 Discussion 3 10th September 2001 01:25
UUC short shifter installed--awesome! steveB E39 M5 and E52 Z8 Discussion 31 29th July 2001 05:48
UUC short shifter Brad K E39 M5 and E52 Z8 Discussion 2 30th March 2001 04:03
