Old 20th February 2003, 19:56   #1
Black M5
Black M5's Avatar
Garage: Black M5
469Bhp E55 vs 444Bhp RS6 vs 400Bhp M5 (long)
Im not sure if anyone on here wrote about this test so here goes..
Its fascinating to watch the speedometer needle of the E55 AMG. Not because its spookingly spindle-less but because it sweeps around the dial at such an incredible rate. If we have filmed it and you could watch it, you'd reckon the footage had been speeded up like a car chase in a bad film.
~The needle is still going strong as it swings for the last marking on the dial, 160mph, when the acceleration abruptly but smoothly tails off- we've hit the 155 mph speed limiter.
How fast would the E55 go if there was no limiter and the straight was two miles long ? 180 ? Easily 200 ? Possibly. A derestricted SL55 made monkeys of a bunch of supecars at a Nardo test organized by Auto Motor and Sport magazine, topping out 202 mph and proving the most accelerative to 170.
A couple of months ago we attachted our own VBOX timing gear on an SL55: 0-60 in 4.6sec and 0-150 in 24.0. Quick huh ? Yeah but the sober looking E55 gets to 150mp/h in just 22.8.
In at least one respect, the E55 redifines the term 'performance saloon'. In this class there isn't a quicker or more powerful four- door; with 469bhp the Merc has 25bhp in hand over its potent rival, the Audi RS6, and almost 70bhp over the iconic BMW M5. In the time the Mercedes takes to get to 150mph, the Audi and BMW have just passed 130mph. And in terms of torque the E55 is even more impressive, its incredible 516lbs ft, over 100lb ft more than the twin turbo RS6 and no less than 147lb ft (almost 40 percent) more than the normally aspirated M5.
~Another car that makes it look like a bargain is the Brabus EV12 that we drove back in issue five. The E55 is actually more accelerative than the 574bhp, 206mph Brabus (verified by the Guinness Book of Records as the fastest saloon car in the World ), and it costs half the price.
Compared with the SL55, the E55 has slightly lower power rating but that isnt the reason it cant quite match the SL's take off. It has narrower rear tyres *265/35ZR 18*, is almost 200kg lighter (weight helps traction), so with less launch bite, the E55 is a couple of tenths behind the SL up to 60 (4.8 vs. 4.6), but once traction has ceased to be an issue it closes the SL down. By 100 mph it has drawn level on 10.2 and by 150mph its over a second ahead.
Genuine supercars dont go much faster, so its no suprise that the Audi and BMW are left in the Mercedes' wake. They're pretty evenly matched, but with its 6 speed manual and rear drive, there's alot more technique involved in getting the M5 off the line to hit 60mph in 4.9 and 100 in 11.5. With no special driver skill the automatic, four wheel drive RS6 will knock off 60 and 100mph in around 5 and 12 seconds all day but turning off wheelspin control, holding it against the brakes and dialing in 3000 rpm, its possible to launch harder and get them down to 4.8 and 11.6.
The RS6 feels mighty quick when you stoke its rumbling twin turbo V8 up to full boost, no question. It delivers the sort of thrust that warrants a warning on its cup holders advising that full power kickdown while carrying hot beverages is not recommended. And yet there is no doubt the E55 hits even harder and faster, exposing a minimal amount of lag that you otherwise wouldn't notice. Similarly, its linear, unrelenting thrust points up a slight flattening of the Audi's delivery in the mid-range.
You look to the M5 with its long established reputation to show how a big performance saloon should behave, and once you've slipped behind the wheel, it feels more right- the driving position is lower and you feel more sucked-in, more a part of the car. Its ride feels initially tauter but its a suprise to see its traction control light flashing almost as often as the Merc's was on the same greasy roads.
The BMW's normally aspirated 5 litre V8 doesn't have anything like the low end surge of the force-fed Merc and Audi V8's but work it through the rev range and its gains lusty strength and purpose above 4000 rpm, lunging for the the redline with a hard yet refined eight cylinder whirr. The sensation of a big, heavy car beneath you is ever present but the difference is that after a few miles your tentative extending of the throttle and pushing against the grip in corners is building rather than eroding your confidence.
~What is enough power for the road ? Everyone has their own idea, and in this class, with rear wheel drive, I dont think the M5 is far off it. In the right circumstances, the E55 feels sensationally faster which, of course, is its own buzz and has an undeniable appeal. As we said at the outset, its extraordinary pace redifines the performance saloon: 0-100 in 10.2 is simply astonishing. Whatever you drive, you'll think twice about messing with the E55 in a straight line, always assuming you spot what it is in the first place.
Yet the M5 has only that to fear. In this class it remains on top because it is the complete package, blending excellent performance with peerless control and percision of chassis, throttle and steering. It would probably struggle to deploy the E55's massive torque and frankly, it doesn't need it. Sometimes you can have too much of a good thing.
Audi RS6..................................M5........... ............E55
Engine... 4.2 V8 Twin turbo.....5.0 NA V8.............5.5 SC V8
Power.... 444@5700................400@6600..........469@6100
Torque... 413@1950-5500......369@3800...........516@2650-4500
Weight... 1865 Kg....................1720 Kg..............1760 Kg
Performance:-
0-30............1.7...........................2.1... ...................2.2
0-40............2.5...........................3.0... ...................2.9
0-50............3.6...........................3.9... ...................3.7
0-60 ...........4.8...........................4.9...... ................4.8
0-70............6.1...........................6.4... ...................5.8
0-80............7.9...........................7.8... ...................7.0
0-90............9.7...........................9.5... ...................8.6
0-100..........11.6........................11.5..... ................10.2
0-110..........14.8........................13.7..... ................12.1
0-120..........18.3........................16.3..... ............... 14.1
0-130..........22.0........................19.9..... ............... 16.5
0-140..........26.2........................23.8..... ................19.5
0-150.............NL..........................NL.... ...................22.8
1/4 mile......13.3@106..............13.4@109.......... .13.1@115
Kickdown:-
................... RS6..........................M5................... .....E55
20-40..........1.6...........................3.0..... ...................1.4
30-50..........1.9...........................2.8..... ...................1.5
40-60..........2.3...........................2.7..... ...................1.9
50-70..........2.5...........................2.7..... ....................2.1
60-80..........3.1...........................2.8..... ....................2.2
70-90..........3.6...........................3.1..... ....................2.8
80-100........3.7...........................4.0...... ...................3.2
90-110.........5.1..........................4.4...... ...................3.5
100-120.......6.9..........................4.9........ .................3.9
110-130.......7.2..........................5.5........ .................4.4
Evo Rating
...................4 1/2 Stars..........5 Stars..................4 1/2 Stars
Evo Feb issue (Power issue)
Black/ Black & Grey E60 /// M5 Nicknamed Mighty M5
Exterior
RD sport front splitters (diablo has a full lip)
RD sport silver CF front inlets
Kidneys painted black (just like diablo)
CF front and rear emblems (just like diablo)
CF double sided bonnet (coated and unpainted- just like diablo )
CF logo
AC schnitzer mono block V. 8.5x20 in the front and 10x20 in the rear. 245/35 ZR20 & 285/30ZR 20
AC Schnitzer roof spoiler (just like diablo)
CSL CF trunk
AC Schnitzer rear diffuser
Smoker LED rear lights (just like diablo)
CF side grillle
V-cool all around tint
Interior
AC schnitzer steering wheel (just like diablo)
CF logo
AC scnitzer black i-drive cover (model of wheels)
Hamann pedals (just like diablo)
CF BMW steering wheel logo (just like diablo)
Trim body matched
Corbeau racing seats. Weigh only 27 lbs
Custom 2 tone interior- black and grey leather with yellow stiching
Custom door panels. same as above.
Performance
EvoSport headers (diablo has SS headers)
EvoSport pulley
ESS computer upgrade
SS race mufflers (diablo has sports mufflers)
SS X pipe (just like diablo)
RPI intake w/black scoops
Brembo 15" front and rear brakes with yellow calipers (diablo has red calipers)
16" OEM fan installed at the front of the radiator
H&R lowering springs
Gone but not forgotten
Supercharged e39 M5 nicknamed El Diablo
700+whp@only 13 psi. Has all the mods in the book minus racing seats.
Sold to board member wilsodh
Black M5 is offline
Old 20th February 2003, 20:11   #2
Ashok Arora
Ashok Arora's Avatar
Thanks for the post. Yet again the M5 comes out on top - and this against the very latest & greatest from the competition. Excellent
Ashok
Let me tell you what SMG stands for...
Ashok Arora is offline
Old 20th February 2003, 20:12   #3
M Power
M Power's Avatar
Garage: Interlagos Blue 2006 / Black extended
Send a message via AIM to M Power
yes sir,
we have discussed this a few times... but it's always good reading how a car already at the end of its 4 year production life holds its own (and then some) against the might of MB and Audi who have had years to play catchup..
M Power is offline
Old 20th February 2003, 20:30   #4
kevin034
kevin034's Avatar
Garage: 2002 BMW E46 M3 Carbon Black
I really don't see the point of these reviews. Even if the W211 E55 beats the E39 M5 ... so what? If I was MB, I wouldn't even allow magazines to comparisions such as this. Why? Well ... shouldn't the new E55 be compared to the E60 M5?
By comparing the new E55 to the E39 M5 and gettig beat on over all performance, you are basicly stating that even given a generation MB still can't match the E39 M5 performance? Isn't this just down right sad?
Back when the E39 M5 and W210 E55 came out, magazines can't stop doing comparisons between the two. Eventually, the MB became just another M5 wanna be w/ a slushbox. This is also sad ...
So what if the W211 E55 can achieve 150+ at around 22 seconds? I am pretty sure that the M5 would match these numbers.
My Point: Comparing cars of two different generations isn't fair in the first place. However, getting your butt kicked by a 4+ year old model is just sad.
my 2 cents.
Kevin
2002 E46/// M3 Carbon Black / Grey
SMGII / 19" M Wheels / H&K Stereo / Navi. System / Bi-Xenon Lights
35% Tint / Valentine 1 / 6000K D2S Lights / Euro Floating Rotors
StopTech Brake Lines / Axxis Ultimate Pads / Eisenmann Titanium Exhaust
kevin034 is offline
Old 20th February 2003, 21:10   #5
Tom C
Tom C's Avatar
Garage: 2002 BMW M5, Le Mans Blue (gone), 2005 CL65 AMG
Kevin:
I have to disagree with the logic used in your argument. On this board we have had many a user question whether they should keep their E39 M5 or get the W211 E55. There is a valid comparison between the two models.
Secondly, using your logic we should question whether the E39 M5 could even be compared to the W210 E55 (yes the "old" E55). There was a slight delay between the introduction of the W210 E55 and our beloved E39 M5. This delay could be as a result of BMW producing the E39 M5 to respond not to the W210 E55 but the W211 E55. The BMW engineering and production people knew back then that they needed to build a car in anticipation of what AMG was going to throw at them 5 years later!
Tom
Tom C is offline
Old 20th February 2003, 21:42   #6
DoctorV8
DoctorV8's Avatar
Garage: 2003 M5 LMB/Caramel
Originally posted by kevin034
I really don't see the point of these reviews.....Well ... shouldn't the new E55 be compared to the E60 M5?
Kevin, how do you suggest the new E55 be compared to a car that hasn't even been shown publicly yet, much less driven by anyone? You gotta compare what on the market currently, right?
As for 0-150, the m5 takes about 30 seconds. Compared to the E55, it's getting all four of it's doors blown off.
It's not "sad" that the E55 still came up short in the comparison...to me, it just speaks volumes on the basic goodness of our E39 M5. I picked this car over the CL55, which IS currently available with the same powertrain as the E. I just like the connected to the road feel of the M5 so much better!
2001 M5 Black/Black, Vortech SQ, Supersprint headers, Tubi, Brembos, KW Variant 3, Dinan wheels/monoballs/S3 clutch/S3 rear subframe, etc....
2003 RUF 550 Rturbo, Slate grey/black
2006 E55 Estate
2009 SL65 Black Series
2005 Ford GT #1119, silver sans stripe, Twin Turbo
2006 C6 Z06, Stage II cam, Ported TB, Kooks headers, Air Charger, Exhaust valve switch
2004 C5 Corvette, F55 Magnetic ride, Pioneer AVIC D1, ATI D1SC Procharger, minitub, Fikse Profil5
1990 C4 Corvette ZR-1 DOHC Lingenfelter 415 cid stroker, coilovers, Wilwood brakes, Fikse FM5
1991 Mustang LX Coupe 331 cid, Incon TT, Griggs, 6 speed, ABS, Big Stuff 3
1978 Lincoln Mark V 460 TT/EFI behemoth project
etc...
DoctorV8 is offline
Old 20th February 2003, 21:59   #7
kevin034
kevin034's Avatar
I guess you guys are right in saying we should compare the best MB and BMW has to offer at this given time. Partly because the market out there will always be looking at what's the best each company has to offer. Also, if my logic applies, then it doesn't make sense comparing the new Audi S4 to the E46 M3 either. So, I agree, we should be comparing the best each company has to offer at a given time.
As for my prior post, all I am saying is that we should keep in mind that, as Tom stated above, BMW designed a car so good that even 5 years later MB's W211 E55 still can't catch up when compared point-for-point performance-wise. The E39 M5 is amazing, able to hold it's own against all the new monsters on the road.
MB makes great soccer mom cruisers, BMW makes great driver's cars. That's what I always say. If the E55 wants to blast the doors off a M5, then let it do it. Atleast the M5 driver can still feel the road at 150+mph.
PS. If a soccer mom passes me on the highway in a W211 E55 AMG, I am going to RMS and getting Emma super charged. End of story.
Kevin
kevin034 is offline
Old 20th February 2003, 22:28   #8
Hamann7
Hamann7's Avatar
Garage: 2001 BMW M5 Carbon Black/ Black Luxury/ Burr Walnut
Send a message via AIM to Hamann7
I'll take a 3 year old M5 over any Merc E55 any day of the week. What the Merc has in acceleration, it more than makes up for the other way in handling. Didn't you guys see that comparison video by some european car show or magazine where the driver ended up spinning the E55 after doing a slalom test?
What a POS.
If I want to go fast, pure and simple, I'll buy a Porsche Turbo and mod it. As fast as you guys think an SL 55 is, let's put it into perspective.
A Manthey 996 Turbo will do 0-200km in 9.3 seconds, faster than the Ferrari Enzo. Ruf R Turbo will do it in 11.8 seconds. This is with $17K in mods for the Ruf and about $50K for the Manthey.
With either of these cars, I would be more than happy to embarrass any of those evil AMG cars.
With prices for the SL 55 AMG going at around $150K-180K around here, I don't see the point in getting one.
If I want a sedan, I'll buy an E39 M5, thank you very much. Even if it is slower in a straight line. To me, it's a Porsche Turbo with 4 doors and better throttle response.
A bit OT I know-- but I can't STAND MERCEDES whoring out the AMG brand! Now you're gonna have soccer moms and other terrible drivers buying 500bhp cars and wreaking havoc on the road. And a suspension that sucks to boot.
BMW M5 - Carbon Black on Black, Luxury interior (SOLD)
Porsche 996 GT2 - Black on Black
Porsche 996 GT3 - Black on Black
Porsche Cayenne S - Dark Sea Blue on Havana
Jaguar E-Type 4.2 - Burgundy on Black
BMW 540i Sport - Gray on Gray
Hamann7 is offline
Old 21st February 2003, 01:35   #9
cjones
cjones's Avatar
Garage: 01 M5
As I said on another thread the E55 is making way more than 469hp. With that kind of trap speed on an automatic car weighing like 4200lbs it's gotta be around 500.
My problem is that I think the DSC in my 01 M5 is too intrusive and the magazine reviews about the E55 say that the electronics drive that car. More intrusive than the DSC? Blah!
Still 115-116mph at 4200lbs is freakin unbelievable for a production car. Put that motor in the SLK32AMG (SLK55 AMG!) and you would have an 11sec 1/4 car. WOW! MB should be proud of that. It's also a beaut. They just need to work on the overall driving dynamic. There is no way that car is a POS though.
I guess if you want a stick get the M5, if you want an auto, get an E55.
01 Carbon Black M5
Supersprint catback, x-pipe, Dinan S3 suspension, BBS RCs, NAV-TV, Dinan S2 software. Slotted rotors. Pics and other goodies at http://www.cjonesy.com/m5
cjones is offline
Old 22nd February 2003, 21:27   #10
Black M5
Black M5's Avatar
Garage: Black M5
Just heard a rumor that MB will be tweaking the E55 to 500hp in 05' in anticapation of the competition coming from the e60 ///M5
Exterior
CF logo
CSL CF trunk
CF side grillle
Interior
CF logo
Trim body matched
Performance
EvoSport pulley
Black M5 is offline
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4494 Yesterday 18:20
2 weeks old: My impressions of the SL 55 vs. M5 (very long) Rezf E39 M5 and E52 Z8 Discussion 34 30th September 2006 02:30
New Jaguar XJR vs M5 vs RS6 vs E55 AMG - Guess who won? Millie Miglia E39 M5 and E52 Z8 Discussion 22 3rd May 2003 17:55
Another EVO test article M5 vs E55komp vs RS6 Fred Jr E39 M5 and E52 Z8 Discussion 5 20th January 2003 04:29
Page generated in 0.21820 seconds with 11 queries
