Old 17th February 2003, 17:32   #1
metzger
Garage: 2002 Sterling grey, silverstone interior; 2000 M roadster, cosmos black
will e46 wheels fit an e39?
I am thinking about putting 19's on my M3 cab, and my brother, who has a 99 540 sport is interested in my 18's if they'll fit his car. Does anyone know the answer? I know the e36 wheels weren't interchangeable, but don't know about the e46. Thanks for your help.
2002 M5, sterling grey/silverstone
2002 Z8, silver/black
metzger is offline
Old 17th February 2003, 20:40   #2
MrGrant
MrGrant's Avatar
Garage: 2002 VW Golf
Hi mike,
I dunno about the technical requirments of fitting but I've seen two e39's (both 530i's) with e46 M3 18's. It looks kinda weird. I don't know if they are copies?
They looked like the real thing (from driving past)?
I've also seen an e46 with e39 M5 18's. Now THAT looks strange.
Personally I don't like the 18" M3 wheels. The 19's on the other hand, luuuuverly...........
good luck,
MrGrant
MrGrant is offline
Old 17th February 2003, 21:08   #3
HaroldC
HaroldC's Avatar
Garage: '07 E60 M5 Silverstone II
Stock E46 wheels will not fit onto the E39 chassis without major work done to the wheels. The E46 uses a 72.6mm center bore, while the E39 uses a 74.5mm (I think) center bore.
It is easier with aftermarket wheels since they use hubcentric rings to change the center bore. This means it is as easy as getting the correct ring for the hub. But there are no rings on OEM wheels.
The only way to get an E46 M3 wheel to fit on an E39, you would have to have someone bore out the hub area on the wheel, and make sure that it is hubcentric. Not an easy task, but it's been done before. Then you would have to get spacers to move the front wheels out to the proper offset.
I do like the way the OEM 19"s look on the E39, but it would be a lot easier to just get aftermarket wheels that fit.
Harold
'07 M5 Silverstone II (RIP)
'03 M3 Titanium Silver
'08 X5 4.8 Space Gray
HaroldC is offline
Will the e46 Space Saver Spare Tire fit e39 M5? BeastPower E39 M5 and E52 Z8 Discussion 6 2nd January 2003 02:21
Could the E39 M5 wheels fit on a E28 M5? atomic80 E28 M5 Discussion 1 12th March 2002 20:57
FS - 18" E39 M5 wheels RL For Sale or Wanted 1 7th October 2000 15:00
Page generated in 0.10841 seconds with 11 queries
