Old 17th February 2001, 08:04   #1
M5Addict
Dinan Stage 1/2 Suspension
Has anyone purchased Dinan suspension parts individually?
I was considering installing the rear swaybar and camber plates by themselves. I don't want the car to ride any stiffer than stock, but would like to eliminate the understeer.
Would this combo work? Thanks.
Alex
M5Addict is offline
Old 17th February 2001, 17:41   #2
Black M5
Black M5's Avatar
Garage: Black M5
My car runs MUCH better than stock! i couldn't beleive that the ride would be alot softer espacially through the putholes. I used to look out for them to try to avoid them, but i know i look for them to ride through them!!!!
Hey if you want to reduce the understeer, get the stage III. Isn't that the cambers job?
By the way, i hear everyone bragging about tire wear and etc. But my front tires are fine, i checked them 2 days ago. The tires are negative slightly but not to the point where you would worry, but its ability to drive and cut turns is unbeleivable
Plus, i drove my car all the way to Indiana 950 miles and back with the cambers on and it is still fine !!! I installed the suspension last summer and i have driven 7000 miles on them including the long trip
Black M5 is offline
Old 18th February 2001, 01:45   #3
AndyMenard
AndyMenard's Avatar
Garage: 2000 Mustang Cobra R
Send a message via Yahoo to AndyMenard
Post
Alex,
I have Dinan Stage II on my machine. Although the ride is a little stiffer, I don't think it is that much to make you want to piece meal the install. I consider the suspension to be one of those things that needs to be "tuned" to the car. I am afraid that if you try to install just some parts without the benefit of others you will suffer from an overall imbalance in the handling of the car.
I would suggest you try to get a ride/drive in someone's car that has the Stage I/II/III suspension on it before you make your final decision.
By the way, Stage II really makes the car handle exceptionally well!!! It definitely improves the understeer problem!
Good luck!
Andy
2000 Imola M5 / Black Nappa - Titanium Trim
AndyMenard is offline
Old 21st February 2001, 08:55   #4
tfung
tfung's Avatar
Post
Black M5, which suspension have you got? By the way, are you the guy with the license plate BMWM5?
tfung is offline
people with stage 3 suspension from dinan... Radar E39 M5 and E52 Z8 Discussion 15 5th April 2003 20:55
Dinan Stage III suspension being removed dwasifar E39 M5 and E52 Z8 Discussion 5 1st November 2002 20:49
Dinan Stage II Suspension Installation (Nightmare) RAREM5 E39 M5 and E52 Z8 Discussion 8 23rd January 2002 05:47
Installation of Dinan Stage III Suspension Diamond Dave E39 M5 and E52 Z8 Discussion 0 18th September 2001 19:15
Dinan Stage two suspension BROKER E39 M5 and E52 Z8 Discussion 6 22nd January 2001 23:26
Page generated in 0.12040 seconds with 11 queries
