• Latest threads
    • Custom feed
      • Updates
        Old 5th February 2003, 03:14   #1 (permalink)
        FAST 5
        FAST 5's Avatar
        Simple question, regarding M5 motor oil...........
        Hi Guys,
        I know BMW uses two different types of engine oil for the M5, one being a thicker weight than the other. I am aware that the thicker of the two oils is hefty in price. But, how about the other "thinner" motor oil, is it also expensive like the thicker version oil? Or is the thinner type less expensive in price? I know I could call the BMW parts dept. tomorrow and get price quotes on the two oils, but I thought someone might know the answer on this board.
        The reason why Im asking this question, is due to the fact, that my sales rep. is going to give me 4 bottles of the M5 motor oil, when I pick up my car at the end of this month. Should I ask for a specific motor oil, thicker or thinner weight ????
        Which one would I be better off with, especially if Im getting it free of charge? Thanks guys for your input. Much appreciated!
        Robert
        FAST 5 is offline
        Old 5th February 2003, 03:24   #2 (permalink)
        Nybes
        Nybes's Avatar
        1450 psi
        I just checked. The VANOS system operates at 1,450psi. Don't y'all think the 10w-60 is a good idea?
        Nybes
        2003 JB/Black Lux
        M-Audio, PDC, Split Seats, Spoiler Delete, Lotsa zymol
        Nybes is offline
        Old 6th February 2003, 21:53   #3 (permalink)
        CEC
        CEC's Avatar
        I remember someone saying the the 10W-60 was around $9 a quart. I just bought 6 quarts of 5W-30 that set me back $25 ($4 each). Go for the 10W-60
        Chet
        CEC is offline
        Old 6th February 2003, 22:44   #4 (permalink)
        willwin2day
        10w-60
        Your dealer has a service bulletin that recommends that all M motors go to the 10w-60. This same question was asked several months ago and I forwarded the sevice bulletin number. If you need the number I can try to find it for you.
        Donnie
        willwin2day is offline
        Old 6th February 2003, 22:51   #5 (permalink)
        FAST 5
        FAST 5's Avatar
        Donnie, Would you be kind enough to forward this information...........
        pertaining to the service bulletin on the motor oil recommendation.
        Thank you so much!
        Robert
        FAST 5 is offline
        Old 6th February 2003, 22:55   #6 (permalink)
        BostonRocket
        BostonRocket's Avatar
        Send a message via ICQ to BostonRocket
        So confusing, this oil issue and our cars. I would use the type of oil that is recommended on the little sticker in the engine bay.
        'Rocket
        H&R Springs
        GONE - 2003 TiAg/Black E39 M5
        GONE - 2001 TiAg/Black E39 M5
        BostonRocket is offline
        Old 6th February 2003, 23:37   #7 (permalink)
        MAH
        MAH's Avatar
        Re: 1450 psi
        It might be a good idea, but according to BMW it is overkill for all M5s built after March of 2000. 5W-30 is the oil recommended after that.
        MY2001 Imola Red
        Lux. Black Interior
        Painted Calipers,
        Autowerke CAI
        Powerchip Software Upgrade
        Tubi Catback Exhaust
        361RWHP
        425HP and growing!
        MAH is offline
        Old 7th February 2003, 00:16   #8 (permalink)
        FAST 5
        FAST 5's Avatar
        MAH, Overkill, in what sense ???...............
        Mah,
        Can you please expand on your comment, regarding the weight of the motoe oil? Thanks a lot.
        Robert
        FAST 5 is offline
        Old 7th February 2003, 02:29   #9 (permalink)
        MAH
        MAH's Avatar
        Re: MAH, Overkill, in what sense ???...............
        Originally posted by FAST 5
        Mah,
        Robert
        Robert,
        All M5s produced prior to March of 2000 were required to use 10W-60 weight oil. This was what the car required because of the rings and pistons that were in production at the time.
        After March 2000 all M5s required 5W-30 weight because BMW changed the rings and pistons from that point in time on.
        I have had both MY00 and MY01 M5s. They had different oil requirements posted in the engine compartment. I saw the same posting requirement for the MY03 M5 as I have on my MY01 last weekend at a local MBW dealership.
        I would assume based on feedback on the board that there has been no change in the posting requirements on the engine of 5W-30 between MY01 to MY03 model years. I have not heard anything to the contrary accept for an advisory that has been mentioned from time to time here. I have not been notified by BMW that they have changed the requierment, so I must conclude that the original posting on the engine is the only correct choice at this time.
        The requirement could change, but no one has produced anything that proves that to this point in time. If someone could post differently, I would stand corrected.
        Mark
        MY2001 Imola Red
        Lux. Black Interior
        Painted Calipers,
        Autowerke CAI
        361RWHP
        425HP and growing!
        MAH is offline
        Old 7th February 2003, 02:58   #10 (permalink)
        FAST 5
        FAST 5's Avatar
        Mark, thanks for that info/reply.
        One last question if i may, wouldn't the thicker oil stand up better than the thinner oil, when it comes to heat generated from the M5 motor. Im guessing that the engine must create a lot of heat under the hood. Any thoughts on this? thank you.
        Robert
        FAST 5 is offline
        Old 7th February 2003, 03:07   #11 (permalink)
        MAH
        MAH's Avatar
        Re: Mark, thanks for that info/reply.
        Robert
        Robert,
        You would be correct in your thinking here, but BMW believes that the synthetic oil (5W-30) will meet their expectations with no problems. Purchasing the more expensive oil(10W-60) certainly is not a bad idea, but not a required one either.
        If you are concerned about the oil breaking down, you might want to change it at the 7500 mile mark. This would still be less expensive than what most of the dealers charge for 10W-60. You can purchase Castrol 5W-30 for $4.99 a quart at Pet Boys. I have seen specials for a low as $4 a quart from time to time.
        Mark
        MY2001 Imola Red
        Lux. Black Interior
        Painted Calipers,
        Autowerke CAI
        361RWHP
        425HP and growing!
        MAH is offline
