Old 1st February 2003, 02:47   #1
1C00lVC
1C00lVC's Avatar
Garage: '01 Ti/silver E39 M5
Send a message via AIM to 1C00lVC Send a message via Yahoo to 1C00lVC Send a message via Skype™ to 1C00lVC
Front signal bulbs
About 2 weeks ago my front left turning signal light was intermittently not working. When it was not working the flicker would click much faster, which I expected. But a light bulb doesn’t burn out “intermittently”, either it works or it burns out. Well 2 days later the same thing happened to my right side front signal, it would work intermittently for a day and then die.
I went to my friendly shop (not the dealer) and as you can see the problem was a burned contact…… On BOTH SIDES! Is this something anyone else experienced?
And a closeup:
Oh yes, after being away from this board for about 2 months I am back. It is good to be back J
Arie
Remember, with an automatic transmission, Shift Happens....
'01 M5 - Titanium Silver/Siilverstone/Aluminum trim
- PDC
- Split seats
- deleted spoiler
- M Audio
- 8000 phone
- Voice Reco
- TV tuner
My Website
1C00lVC is offline
Old 1st February 2003, 02:52   #2
Gustav
Administrator
Gustav's Avatar
Nice detailed camer BTW. Pictures say more than a thousand words.
Gustav is offline
Old 1st February 2003, 06:16   #3
EXLR8ING
EXLR8ING's Avatar
Garage: 2001 Jet Black BMW M5
I experienced the same problem with my passenger-side front turn signal. I took it to the dealership twice before a final fix occurred. During the first trip, the dealership replaced the bulb and the socket. A few weeks later the bulb shorted which caused the rapid flickering when activated. I went back again for the correct fix. Apparently, the bulb design was defective and the unit would burn-out (short) at the contact points in the socket, not the element itself. The dealership replaced the bulb with the newer designed bulb and all has been well since the installation over six months ago.
Chuck - 2001 Jet Black/Black, Tinted Windows, B&B Triflo Exhaust
EXLR8ING is offline
Old 1st February 2003, 07:08   #4
Need4Spd
Need4Spd's Avatar
Just had mine replaced under warranty, too. Passenger side. A few weeks ago, the driver's side quit working, but it was a broken wire! I figure it somehow it got pinched during manufacturing, as I certainly hadn't done any work in that part of the car. At the time, I figured it wasn't worth my time to bring it to the dealer, so a bit of solder, some heat shrink tubing and a splice wire later, and it was good as new. Of course, then the passenger side went and the socket needed replacing, so I had to go to the dealer anyway!
Need4Spd is offline
Old 1st February 2003, 09:17   #5
cjones
cjones's Avatar
Garage: 01 M5
Same thing on my passenger side right now. Intermitent. Dropping if off next week to get fixed.
cjones is offline
Old 1st February 2003, 11:25   #6
tonyo
tonyo's Avatar
Garage: 2008 Space Gray M5
It's happened several times to me so far. (this sounds familiar, must've posted before...)
I always request a new socket with the new bulb. I'm hoping that one of these days, they'll have redesigned it and I'll get the better one....
'08 E60 Space Gray M5
'01 E39 Le Mans Blue M5
'99 550 Maranello
'98 Supra
tonyo is offline
Old 3rd February 2003, 17:26   #7
atomic80
M5 Extraordinare!
atomic80's Avatar
Garage: 2007 Cobalt Blue Porsche 997TT
I'm not sure what you mean by that. My '01 M5 has the regular bayonet type as opposed to the "stick-in" type that Arie seems to have.
Jason
'05 Range Rover w/mods
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 3rd February 2003, 17:46   #8
MAH
MAH's Avatar
Garage: 2001 Imola Red
Re: Front signal bulbs
And a closeup:
I have had the exact same thing occur on my car. I had to take a piece of wire and wrap it around the base to secure it in the slide in socket. This prevents the bulb from slipping back out and causing this short to occur. A very poor design indeed.
Both of my turn indicators have this problem. If you push the bulb back into the socket, it just pops back out from time to time.
This happened to me when I was testing the LED turn indicators. The LEDs have the same base, but do not pop out. This being said, I believe that the base is the problem and in light of the shorting that you have seen as well as I, THIS SHOULD BE A RECALL FROM BMW BEFORE YOU GET A REAL FIRE!
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
MAH is offline
Old 3rd February 2003, 17:48   #9
atomic80
M5 Extraordinare!
atomic80's Avatar
I don't get it...why does some 2001 M5's have these bulbs while others like mine doesn't. Was this something that was changed mid-year?
Jason
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 3rd February 2003, 17:52   #10
MAH
MAH's Avatar
Jason,
You mean you have a different bulb and base than the ones shown above? Yous is not a slide in style?
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
361RWHP
425HP and growing!
MAH is offline
DSP wiring pinout 1C00lVC M5 E39 and E60 tips & tricks 3 30th September 2004 05:09
How too change the front turn signal bulbs? Micsor/DK E39 M5 and E52 Z8 Discussion 2 29th March 2002 17:34
How too change the front turn signal bulbs? Micsor/DK Off Topic Forum 0 29th March 2002 09:17
HID 9006 foglight bulbs for M5 atomic80 E39 M5 and E52 Z8 Discussion 4 1st June 2001 16:29
Page generated in 0.17428 seconds with 11 queries
