Old 31st December 2002, 10:03   #1
BeastPower
Guest
Will the e46 Space Saver Spare Tire fit e39 M5?
I was interested in carrying a space saver spare in the truck, in case the M-Mobility system can't fix the damage (e.g. blow-out). Will the space saver spare that comes with the e46 fit the e39 M5 (with front Brembos)? I am assuming the answer will be NO, so ... on to the next part of my question:
Is there a space-saver available from any manufacturer that can fit on the e39 M5 with front Brembos?
Plus, who sells a good bottle-jack in case I need to replace the wheel?
Thanks.
Old 31st December 2002, 15:39   #2
Teutonaddict
Teutonaddict's Avatar
Garage: '00 Carbon Black/Black All-Leather/Sportive
Not sure where we ended up....
...the idea of a space-saver came up a while ago--before the E46 M3; I wasn't aware it had one. Some folks talked about adapting a Corvette space saver, and someone else went to the expense of having Kinesis manufacture a skinny-profile forged three-piece to go over big brakes.
As for the bottle jack, why not get the factory scissors jack that comes with every other E39? As I recall it worked fairly well on my E39 540i/6. There's also a place for it to fit in the side panels of the trunk, if I recall correctly.
Let us know what you find out!
BOTH SOLD!!
#101421
Teutonaddict is offline
Old 31st December 2002, 20:11   #3
stever
i did a lot of investigation and never pulled the trigger
the largest spacesaver wheel size i'm aware of is 17 inch
i can't seem to find my notes at the moment, but the tire size used on the Corvette or the Mitsu VR4 (next smaller section) had the correct diameter and adequate weight capacity
the Corvette bolt circle should actually fit the M5 but there may be a hub-centric problem and and offset problem
the Brembo brakes will be a big problem, you'll have to lay out actual caliper and wheel dimensions to see if the wheel can be spaced out enough to clear the caliper -- certainly will be a custom wheel
i think i can clear my StopTechs with a custom wheel and will continue to pursue this when i get around to selling my old front wheels and tires
never heard any results on the custom Kinesis wheel, the guy seems to have dropped off the board
stever is offline
Old 2nd January 2003, 01:23   #4
BeastPower
Guest
Thanks for your responses. I will probably end up just putting a tire on my spare Dinan wheel and throw it in the trunk. It is a rear wheel, but hopefully it will work on the fronts too.
Cheers.
Old 2nd January 2003, 01:25   #5
johann
Administrator
johann's Avatar
Garage: BMW E39 M5, Carbon black
Send a message via MSN to johann
Re: Not sure where we ended up....
It doesn't.
And the normal E46s have smaller hub center than E39 so they will not fit either.
johann is offline
Old 2nd January 2003, 01:51   #6
BeastPower
Guest
The e46 3-series convertible has a space saver spare! I should know as my wife has a 2001 330ci Convertible .
Old 2nd January 2003, 02:21   #7
johann
Administrator
johann's Avatar
That's not an M3, is it?
johann is offline
Dinan Exhaust AlbertM E39 M5 and E52 Z8 Discussion 10 26th December 2009 06:29
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4496 22nd November 2009 09:15
M5 wheel and tire dimension survey stever E39 M5 and E52 Z8 Discussion 0 15th April 2001 00:21
Page generated in 0.14839 seconds with 11 queries
