Old 30th December 2002, 04:42   #1
01M5
01M5's Avatar
Garage: 01 LeMans Blue M5
Brake Bleeding
Since brake bleeding is such an important issue...what is the best way to do so? There are some brake bleeders such as Griot's Garage (sucks fluid out) and AJ-USA (pushes fluid through http://www.ajusa.com/cgi-bin/invento...gory?cat_id=15)
What is the best bleeder for those with and without an air compressor?
01M5 is offline
Old 30th December 2002, 05:11   #2
DZeckhausen
DZeckhausen's Avatar
Garage: 2001 540i 6-Speed, Alpine White
Send a message via AIM to DZeckhausen
Re: Brake Bleeding
I wrote a post on this topic on the Roadfly message board. The folks at BMWtips.com grabbed it for their archives. You can see it here: http://www.bmwtips.com/tipsntricks/b...ol/bleeder.htm
If you've still got questions after reading it, just let me know and I'll try to help.
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
DZeckhausen is offline
Old 30th December 2002, 05:28   #3
01M5
01M5's Avatar
Superb
Thanks Dave! That's exactly what I was looking for. Nice job describing the different types of bleeders.
Would you mind posting your exact procedure for bleeding brakes?
01M5 is offline
Old 30th December 2002, 05:29   #4
01M5
01M5's Avatar
One more question-where do you purchase a bleeder like you mentioned in #5?
01M5 is offline
Old 30th December 2002, 05:33   #5
Mel A
Mel A's Avatar
Garage: 1988 E30 M3 Race Car
An inexpensive and very effective way of bleeding your brakes is changing the bleed nipples to Speedbleeder nipples.
I've used this method for about 3 years with no problems-it's quick and easy and you can do it alone.It's great for drivers schools.
Here's a picture:
http://www.speedbleeder.com/images/sbani.gif
Go to their website:
Mel A is offline
How to install LED brake lights atomic80 M5 E39 and E60 tips & tricks 0 2nd September 2002 03:01
Had to remove the LED brake lights - interferred with the HID fogs MAH E39 M5 and E52 Z8 Discussion 10 26th July 2002 17:16
Bleeding clutch and brake karlcchen E34 M5 Discussion 1 27th December 2001 00:23
Has anyone used Castrol SRF brake fluid? Ilya Zverev E39 M5 and E52 Z8 Discussion 1 6th October 2001 04:36
Page generated in 0.13706 seconds with 11 queries
