Old 29th December 2002, 19:58   #1
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
Parking Brake Handle Removal?
OK Guys! Bought a nice chrome & carbon fiber parking brake (e-brake) handle for my 2002 Beast.
Before I screw up something, can anyone tell me how to remove the old handle? I removed the leather boot and cut off the black cable tie that encircled the leather stock handle at its base, but now how do I get the old handle off to replace it? The new handle has a hex wrench set screw but I don't see a set screw holding the stock handle in place.
Thanks for your help in advance!
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
Old 29th December 2002, 23:12   #2
mustang
mustang's Avatar
Garage: 2000 M5 Titanium Silver
I replaced mine. Its a bit of a chore. A side panel next to the drivers seat needs to come off as does most of the console. There are a couple of bolts that hold the parking brake handle on - one on the top and one on the bottom. I got one of my local automotive shop guys to give me the removal instructions. That'd be the best way but you should be able to figure it out. Start with removing the rear air vents in the console and the ash tray and flasher. You'll see the hold down bolts.
mustang is offline
Old 29th December 2002, 23:31   #3
XrayMD
XrayMD's Avatar
Whoa!!! I'm not talking about removing the entire lever, just the leather handle on the end. You shouldn't have to do any of that (I don't think anyway) to just do that. The handle just goes on the end of the metel lever. Thanks!
Steve
'02 M5 LeMans Blue:
RMS short shifter
XrayMD is offline
Old 30th December 2002, 00:33   #4
TriflowM5+M3
 TriflowM5+M3's Avatar
Garage: 01 Lemans Blue M5
you are getting to be my second twin
Steve...
you bought the ebrake handle from bav auto didnt you! Man im going to have to come up to OH and have some words with you reguarding our selections of the same gear
Im interested to know how to switch out the ebrake as i want that one from bav and since its on sale...even more reason to figure out. I just looked on line today and was getting itchy to post something about how to do it...and poof, someone else beats my thoughts.
 TriflowM5+M3 is offline
Old 30th December 2002, 01:04   #5
XrayMD
XrayMD's Avatar
Yep! I bought the handle from BAV and it was the one on sale! This is getting scary! We're thinking too much alike! I haven't figured it out yet. The new handle looks simple. It's essentially a hollow tube made out of chrome and carbon fiber and has a larger opening at the base and a smaller opening at the end. The smaller opening is obviously for the parking brake release button. On the bottom of the base of the new handle is a small hex set screw and it comes with the appropriate hex wrench.
I pulled the leather boot off from the console (very easy...held in place with a few clips that just undo as you pull the boot from the top) and as you roll it up towards the handle, you will find a black cable lock tie that encircles the leather boot and holds the boot onto the base of the e-brake handle and keeps the boot from slipping back towards the console. No problem up to this point but now I'm stuck because I can't see how the old handle comes off! There's not a set screw holding it in place. I'd feel stupid if I had to have the dealership change this for me, hence my post for help. I'm not sure that the answer I received is right. It just seems that you shouldn't have to get into the console just to remove the hand-grip part of the handle. If you find out the way to do it, please let me know. I did a search for the subject before I posted the ? and found a few references about replacing the grip because of peeling, but no one said how to do it and I believe they were done by the dealer.
BTW, I also ordered ACS pedals and are waiting for them to be drop shipped.
Steve
'02 M5 LeMans Blue:
RMS short shifter
XrayMD is offline
Old 30th December 2002, 02:59   #6
mustang
mustang's Avatar
XrayMD
Sorry, I was talking about replacing the entire parking brake assembly. You must not have to do that. However, I don't have any idea how to remove the existing handle. Are you sure the new doesn't just slip over the old one? BMW sells one like that with the brushed aluminum look - its for the cars with that standard emergency brake - and it just slips over the existing handle.
mustang is offline
Old 30th December 2002, 03:47   #7
XrayMD
XrayMD's Avatar
Mustang...
Nope, it doesn't fit over the old one! I think I'm going to have to give Bavarian Auto a call tomorrow and see if they can help me. Thanks anyway!
Steve
'02 M5 LeMans Blue:
RMS short shifter
XrayMD is offline
Old 30th December 2002, 04:24   #8
LSU1981
LSU1981's Avatar
Garage: 2000 M5 Avus Blue
Send a message via AIM to LSU1981
Originally posted by XrayMD
......BTW, I also ordered ACS pedals and are waiting for them to be drop shipped.
XrayMD,
Did you consider these petals?
AJUSA
I like the idea of the accelerator extension for heel/toe. Has anyone got any experience/feedback with this type of setup?
Good luck with the e-brake handle!
2000 M5 Avus Blue / LeMans Sport. (sold to MPRESIV, 9/04)
2002 M3 Carbon Black/black
2004 Sierra Denali
2008 335xi - on order
Gone - Shelby Cobra Roadster, 01 Carrera C2 Coupe, 00 M5
LSU1981 is offline
Old 30th December 2002, 04:38   #9
01M5
01M5's Avatar
Garage: 01 LeMans Blue M5
Originally posted by LSU1981
XrayMD,
AJUSA
Nice pedals I love the accelerator extension.
They have a brake bleeder....does anyone know about it? I'll start a new thread.
01M5 is offline
Old 30th December 2002, 17:59   #10
TriflowM5+M3
let me know what they tell you
Steve
let me know what Bav tells you as im really interested in getting that Ebrake handle after the christmas season. Now, i might be getting something before you though....new rogue sway bar brackets. Maybe.
parking brake doesn't hold MBrown1003 E39 M5 and E52 Z8 Discussion 41 5th August 2004 14:24
Need help with Lug stud length V-10 4 Me E39 M5 and E52 Z8 Discussion 21 27th October 2003 20:09
Aluminum shift knob and brake handle Sysko E39 M5 and E52 Z8 Discussion 11 3rd August 2003 07:16
parking brake handle mustang E39 M5 and E52 Z8 Discussion 4 13th April 2002 08:13
Removing emergency brake handle MarcK E39 M5 and E52 Z8 Discussion 10 22nd April 2001 02:08
Page generated in 0.14777 seconds with 11 queries
