• Latest threads
    • Custom feed
      • Updates
        Old 19th December 2002, 19:46   #1 (permalink)
        jdv
        jdv's Avatar
        Weird change in exhaust note/sound??
        I own a 2001 M5 (build 10/00) with a problem I have not encountered or heard about. Yesterday, while driving normally around town (non spirited...) the exhaust note of the car dropped about 2 octaves and got significantly louder, just as if there had been a hole in the exhaust manifold or system. At the same time, the SES light popped on.
        I was close to a mecahnic/friend with a lift in his garage and drove over, only to have the sound change to normal in ten minutes or so. SES light remained on. Got the car in the air; absolutely no problem anywhere with the exhaust system. Drove it home, normal sounding exhaust note, SES light still on and called service advisor last night.
        This morning I start the car to move it to take another vehicle to the office, no SES light, no change in exhaust note, still normal. Waiting for a call from the dealer.
        The car has around 12,000 miles on it, only modification is a Dinan exhaust which has been on the car for a long while, anyone out there have any bright ideas?
        Thanks, very much,
        John
        jdv is offline
        Old 19th December 2002, 19:49   #2 (permalink)
        TriflowM5+M3
         TriflowM5+M3's Avatar
        interesting
        Have you driven the car hard with the exhaust on it before? I know that the M5 driving experience M5's sound totally different from a stock one.
        Wondering if the tone changed because there might have been some baffling that let go, hence causing a flow increase (setting off a SES light) and causing the drop in tone (lower restriction lower tone??)
        Just some thoughts...probably wrong though
         TriflowM5+M3 is offline
        Old 19th December 2002, 20:18   #3 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        This was covered in the past...I can't recall what was causing the problem but I think it was something to do with the VANOS or even the exhaust system.
        Some people actually reported liking the new sound. What about you. Do you like it?
        Jason
        '05 Range Rover w/mods
        '05 K1200S w/mods
        '07 997TT w/mods
        atomic80 is offline
        Old 19th December 2002, 21:40   #4 (permalink)
        kees
        Administrator
        You can find a previous thread on this problem here.
        kees is offline
        Old 19th December 2002, 21:49   #5 (permalink)
        DarkStar
        DarkStar's Avatar
        sounds like cam sensor issue....
        //DH
        DarkStar is offline
        Old 19th December 2002, 22:18   #6 (permalink)
        Need4Spd
        Need4Spd's Avatar
        Definitely a cam sensor issue. I had the same problem. The sensor alters the ignition timing, which affects power output and also the sound the exhaust makes. Have it fixed under warranty. Even though it's intermittent, they should be able to diagnose it from the stored fault codes, and trust me, it will eventually become full time.
        Need4Spd is offline
        Old 19th December 2002, 22:37   #7 (permalink)
        BostonRocket
        BostonRocket's Avatar
        Send a message via ICQ to BostonRocket
        I think it's the cam sensor.
        I had the same problem on my old M5. I tried to get it diagnosed as a cam sensor, but they couldn't produce the right fault code. But I was certain that it was it.
        'Rocket
        H&R Springs
        GONE - 2003 TiAg/Black E39 M5
        GONE - 2001 TiAg/Black E39 M5
        BostonRocket is offline
        Old 19th December 2002, 23:05   #8 (permalink)
        jdv
        jdv's Avatar
        Thanks all. Triflow, it is quite different than just driving hard. Atomic 80, I too like the sound, but I think it would set off a lot of car alarms. Thanks Keesdh, that thread is dead on, I appreciate it.
        Will let you know what the dealer says, they called and said to bring the car in and that they had a BMW loaner for me to use in the interim.
        John
        jdv is offline
        Forum Jump
        Group buy yet on Tubi???? Stevus M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 381 15th December 2004 00:09
        ACS exhaust write up TriflowM5+M3 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 15 25th June 2003 14:18
        For you guys with Kellener's exhaust (83 mm size) I have a question for you, please.. FAST 5 E39 M5 and E52 Z8 Discussion 5 10th December 2002 14:56
        TriFlo exhaust decided to change its tune today GradX E39 M5 and E52 Z8 Discussion 2 29th March 2001 02:37
        Help me to change exhaust system Jean-Christophe E39 M5 and E52 Z8 Discussion 10 11th November 2000 09:12
