DIY adjust front camber without plates - BMW M5 Forum and M6 Forums
Like Tree1Likes
  • 1 Post By nightkrawler
Old 27th April 2013, 00:46   #1
nightkrawler
nightkrawler's Avatar
Garage: 03' M5
Sales Feedback: (3)
My new M5 has H&R springs in the front. First alignment on her the front camber was out of spec too far. I was going to get camber plates but i wanted to try something first. Most bmw's have a slight bit of adjustment for front camber, approx .5*. You adjust it by slackening the front strut nuts and sliding the strut left or right. So I took the dremel and extended the holes where the upper strut mount studs go through the tower. I did another alignment a few days ago and now the readings are in spec. Im going to extend them a bit more so I can get it closer to where I want it. Unfortunately I didnt print out the specs from the first alignment but I know the front camber was in the red. Now after adjusting it, back in the green(in spec).
Correct me if im wrong with my specs.
E39 M5 front camber spec -1.0* to 0.0*
mine are currently
left -0*40' right -0*46'
so if my conversion is correct -40 minutes/-46 minutes converts to approx,
left -.65* right -.77*
nightkrawler is offline   Reply With Quote
The Following User Says Thank You to nightkrawler For This Useful Post:
Sailor24 (27th April 2013)
Old 28th April 2013, 01:24   #2
POOFY
POOFY's Avatar
Garage: '03 M5 carbon black
I've thought about this bit never looked into it. What would be the draw backs? I would like to be able to add camber for track use and then put it back for street.
POOFY is online now   Reply With Quote
Old 28th April 2013, 23:53   #3
Scott the Pict
Garage: M5 E39 Le Mans blue 2000 some minor rust clutch slips on power changes middle pixels are mostly gone need to do diff. oil and gearbox oil
It's an old trick for cheaply getting more negative camber at the front.
Good for better turn in and cornering.
As standard my rears wear out the inside first (because of the negative camber)
The fronts wear on the outside edge very quickly (big heavy car, lots of roundabouts)
This "trick" would help reduce understeer. (mattmartindrift)
Would slightly reduce outer edge wear on fronts also?
Scott the Pict is online now   Reply With Quote
Old 29th April 2013, 00:54   #4
nightkrawler
Garage: 03' M5
Sales Feedback: (3)
i did this to get more positive camber as with the lowering springs in the front it was out of spec, too negative. if you want to do this to get more negative camber then you have to ream out the holes in the opposite direction.
Old 29th April 2013, 03:47   #5
POOFY
POOFY's Avatar
I understand the why's (I do drive an M5, lol), I'm wondering if there could be some negative effects to making the holes bigger, structural integrity and all. Another way to put it is why doesn't everyone do this? Seems like a great idea to me.
Old 1st May 2013, 03:17   #6
nightkrawler
Garage: 03' M5
Sales Feedback: (3)
you would probably have to make the holes the size of a half dollar to weak the strut tower, reaming them out a bit like this will cause no problem. why more people dont do this i dont know.
POOFY (1st May 2013)
Old 16th May 2013, 23:50   #7
nightkrawler
Garage: 03' M5
Sales Feedback: (3)
did another alignment a week or so ago. now i got the front camber exactly where it should be, -.33' left and -.34' right, which translates to about -0.50 degrees.
Dinan Camber Plates- DIY? Mike Krieger E39 M5 and E52 Z8 Discussion 5 8th July 2008 16:48
K-mac front camber plates, need some input! leburpor E60 M5 and E61 M5 Touring Discussion 4 1st May 2008 13:32
9.5" Front Rims w/o Camber Plates - Enough Clearance? IRISH M5 E39 M5 and E52 Z8 Discussion 83 9th April 2008 06:47
Front camber plates for EDC? corneredge E34 M5 Discussion 18 23rd August 2006 17:41
wtb Dinan front strut brace and camber plates mishkinm5 Parts / Other For Sale or Wanted 0 12th June 2006 05:13
