how does dealer fix cocked steering wheel? - BMW M5 Forum and M6 Forums
Old 19th November 2002, 23:39   #1
Magna
Magna's Avatar
Garage: 2000 323i Sport Package
had an alignment done but now the steering wheel has to turned to the right for the car to go straight. i am bringing it back to dealer to fix problem. will they re-align my car or just adjust the tie rods by sight?
how do they fix a cocked steering wheel, or perhaps my car is mis-aligned. in any case, thanks everybody for any info on subject.
Magna is offline   Reply With Quote
Old 20th November 2002, 00:11   #2
Paul S
Paul S's Avatar
Garage: Silver cars
99.9% sure it's misaligned. don't they check this stuff before they call you to pick it up?
'07 M Coupe/'06 C2S/'04 X5 4.4
Paul S is offline   Reply With Quote
Old 20th November 2002, 01:24   #3
Need4Spd
Need4Spd's Avatar
The alignment may be correct, but they didn't do the job right. They're supposed to center the wheel and settle the suspension before doing the adjustments. Bring it back and insist on them making this right. And because this means you had to make an extra trip to the shop, they should give you a loaner car or at least give you a free detail for your trouble.
Need4Spd is online now   Reply With Quote
Old 20th November 2002, 14:52   #4
TriflowM5+M3
 TriflowM5+M3's Avatar
Garage: 01 Lemans Blue M5
Have the same prob
Had a lower tie rod go...caused a god-awful squeeking when i went around right hand turns. So they replaced it and did an alignment. I know that the car needed one because it was some what due for one, but it got worse when I got it back...have to steer about 3/4" to the left to go straight. Im just making a huge list for the dealer to complete when it goes in for the clutch.
Install Stainless Brake Lines
Flush Brake System, Refill with Super Blue
Clutch
Flywheel
Refill Trans with Super Blue
Realign the car
Paint is starting to flake on the right side of the front facia...what the heck is that?
 TriflowM5+M3 is offline   Reply With Quote
E60's active steering, from AutoBild :) Micsor/DK E60 M5 and E61 M5 Touring Discussion 2 23rd August 2002 22:24
Automatic steering wheel tilt krullshards E39 M5 and E52 Z8 Discussion 20 20th August 2002 16:44
'00 steering wheel for '01 steering wheel?? steveB E39 M5 and E52 Z8 Discussion 14 17th April 2002 17:35
"ORDER / PRODUCTION SUMMARY" ( Note : See First Post For Instructions ) Alan A E39 M5 and E52 Z8 Discussion 82 17th March 2002 06:50
steering wheel with aluminum inserts ? Black M5 E39 M5 and E52 Z8 Discussion 7 14th August 2001 17:21
