Check Brake Lining Warning?? - BMW M5 Forum and M6 Forums
post #1 of 2 Old 19th November 2002, 09:10 PM Thread Starter
fais2000
fais2000's Avatar
Exclamation Check Brake Lining Warning??
Have any of you gotten the msg "Check Brake Lining" ? I am getting this message and my brake light is on (not parking brake but another turned on). Any ideas?? I just had my mechanic chnange the front brakes anyway (they were kinda low) but dont know about this one.
tia
fas
fais2000 is offline
post #2 of 2 Old 19th November 2002, 10:15 PM
rvacha
rvacha's Avatar
BMW uses little electromechanical sensors embedded in the rear passenger and front drivers brake pad. These are usually fool-proof and normally don't false alarm so I would say that either:
1. One of the monitored pads is truly worn down to the sensor
2. The connector that connects the sensor wires to the body cabling is corroded or intermittent. Try unplugging/plugging them a couple of times
Has the light been on since the brake job? I recently changed my pads, and the light came on afterwards. Turns out that the sensor connector was having problems making a good connection with the body cable. To figure out which is the problem, take an old sensor, cut the sensor off, strip the the two leads, and twist then together. Then take this and plug into the front (way easier to get to in an E39) and then the back to see which one is problematic. If you are handy with a meter, a worn sensor will measure open (very high resistance).
Hope this helps
Ray
'03 E53 X5 4.4i Topaz/Sand
'06 E90 330Xi 6MT Sparkling Graphite/Terra
'08 E92 M3 6MT Jerez/Speed Cloth/Carbon Leather <-- Evil Twin
rvacha is offline
Check Brake Lining - minor rant & question Steve Morling E39 M5 and E52 Z8 Discussion 10 11th March 2003 10:10 PM
Problems to look out for when buying M5's BarryP E34 M5 Discussion 29 17th September 2002 06:52 PM
pre-purchase inspection paolo E34 M5 Discussion 8 28th April 2002 11:46 PM
Inspection I & II checklist please IvanDias E34 M5 Discussion 2 2nd November 2001 03:31 PM
Check Brake Lights adamma E39 M5 and E52 Z8 Discussion 1 31st August 2001 08:13 PM
