Old 19th November 2002, 01:24   #1
tfung
tfung's Avatar
icy rain driving
Don't think anyone has mentioned it before, but I guess it could also be common knowledge.. since I'm from Hong Kong and very seldom drive in conditions like I did today, I thought I would share in case other people didn't know...
was driving back from Toronto to Boston today, and the conditions were pretty bad today... icy rain mixed with snow, etc... While driving on the highway, I noticed that after driving about an hour or so without using the brakes at all, when I needed the brakes all of a sudden and stepped on the brake pedal, the brakes don't bite at all! It takes roughly 2 seconds before it grips... I don't know what happens, but I presume that the water sort of freezes on the brake pads and it takes longer than usual for it to grip because of the ice? so after a few times like that today, I learned to use the brakes once in a while so that in case of a real emergency, the brakes won't hesitate to grab... :p
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
tfung is offline
Old 19th November 2002, 01:32   #2
Guest
Tfung, I've heard about the Ice/snow storms hitting some parts of the East Coast....Good Job you came back in one piece!
Doesn't Mercedes's Electronic Brakes Feather the Discs when it's raining, automatically?
Old 19th November 2002, 01:32   #3
BoringFamilySedan
BoringFamilySedan's Avatar
Garage: '01 M5 (Le mans blue on Le mans blue)
Send a message via ICQ to BoringFamilySedan
yeah.......the weather is terrible here so we couldn't even meet up!!!
we have the same brake problem as u mentioned after auto car wash @ gas station coz the blow dryer doesn't make the water on our brake disks goes away. so mostly we have to keep braking till we actually feel the brake is working properly.
Dinan: Stg 3 Software, CAI with all updates, Flow meters, exhaust, 3.45 diff, Stg 3 Suspension, Front Strut Brace, Rear Shock Brace, Wheels (Tires: Front 265/Rear 275), Floor mats
Others: AC Schnitzer Front Spoiler, AC Schnitzer Foot Pedals, 6000K, Brake Ducts, M Audio woofers, UUC Flywheel+Clutch, UUC EVO3 SSK
BoringFamilySedan is offline
Old 19th November 2002, 02:11   #4
chunpng
chunpng's Avatar
Garage: M5, silver/black
I've also read somewhere that driving in low temp. conditions, one should brake gently, intermittently to keep the brakes warm.
No practice here in the Bay Area though. 72 degrees out with featherly clouds. We have such rough weather here.
Keep safe.
CP
CP
00 Titanium Silver: 6/00-1/05 RIP
95 Black Metallic RUF BTR-2
07 Meteor Grey Cayman
chunpng is offline
Old 19th November 2002, 04:59   #5
Rezf
Rezf's Avatar
Garage: 08 Aston Martin Vantage (Stratus White)
Terence,
What you expereinced is not a "cold" weather/icy rain phenomenon, but rather due to rain (water) building up around the brake pads, like a film. In wet conditions, you should periodically hit your brakes, in order to keep them "dry" so they have the intended efficiency. I have expereinced what you described in the middle of July during a rain storm
RezF
2008 Aston Martin Vantage
2008 X5 3.0 Mineral Green with ALL options
Rezf is offline
Old 19th November 2002, 04:59   #6
TCM
TCM's Avatar
Glad to see you made it back in one piece Terence. I would have thought the roads would have been half way decent but I guess not. As far as the braking in the rain, you are supposed to apply your brakes every so often in wet conditions, I beleive it states that in the manual. The water build up on the rotors decreases brake performance so by applying the brakes every so often you clear the rortor surface so you can have consistent brake performance when needed as the pad makes direct contact with the rotor. You will also see pro racers always tap the brakes on long straights when it rains to make sure they have good braking capabilities for the end of the straight.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 19th November 2002, 09:45   #7
chazzy
Garage: '01 M Coupe - Sapphire Black
On the new E-Class (and the SL, I think), the Sensotronic Brake Control touches the brake pads to the rotor periodically when the wipers are going to keep the pads and rotor dry. Neat feature that will show up in other cars, for sure.
'01 M Shoe, Sapphire Black Metallic
368S/4
chazzy is offline
Old 19th November 2002, 10:46   #8
ycchan
Garage: Golf GTI
tfung,
were you driving with snow tires?
ycchan is offline
Old 19th November 2002, 11:08   #9
Kurt555gs
Kurt555gs's Avatar
Garage: 2002 BMW M5 RED
Send a message via ICQ to Kurt555gs Send a message via AIM to Kurt555gs Send a message via Yahoo to Kurt555gs
I had an interesting icey drive last weekend
When I bought the M5 I figured that I would just drive it on summer evenings and weekends .... well the problem is ... well I just love driving the thing and I keep making excuses to just go some where. I got it brand new in April this year and it is approaching 20K miles.
So last weekend , the fam wanted to go to the weekend house in Fennville Mi (about 2.5 hours from Joliet) ...... but I suggested it would be fun to take a "ride around the pond" ... so ... the fam aka wife and teenage creature daughhter thought .. oh well he is crazy but sometimes fun ... so .... lets go.
Ok so instead of heading to Michigan we went north , through Duluth Mn ... then up to Thunder Bay On.
Well ... I wanted to stay in Thunder Bay .. but wifey and Teenage creature daughter said ... it's only 4:00 PM .. lets keep going .... I explained that I had done this trip many times before and there isnt much heading east .... they insisted however so ... off tword Nippigon we went.
Then it started to sleet , and the fog rolled in at the same time ...
Since the M5 doesnt have de-icing boots on it's leading edges .. lol i noticed that ice was building on the mirror shrouds , and everywhere else ... like the road.
Any one who has ever taken 11/17 around the north shore of Superior can appreciate this, but it is had to put to words the excitement that driving on twisty, mountainous roads on glare ice at night in the fog can bring.
well .. the outcome ..... DSC works, although it was lit up like what you would normally see of worning lights on mid 70's ghetto cruisers, I didnt slide off into the canadian wildness.
We got to Nippigon, and found a motel ... I can sleep in a hallway, but my wifey & teenage creature daughter found the accomidations lacking .. lol
Only place that had rooms was .. well ... one of those places no one ever admits to being in .. but one would imagine ending up there with a lady that has .. well .... lets say a very low TOOTH / TATOO ratio ....
Anyway ..... rest of the trip was fun except that Canadians seem to like to obey speed limits (90 kp/h) when there doesnt apear to be the need to ........... and US Customs was a pain comming back through at Ste Sault Marie MI .....
Oh well .. the M5 is no worse for the experince except for the now custom grips in the steering wheel and the vertical crease in the seat cushin
cheers
Kurt
02 Imola Red M5
04 BMW R1150RT (blue)
http://kurt.bihlertech.com/~kurt/
Kurt555gs is offline
Old 19th November 2002, 12:02   #10
SUPRA
SUPRA's Avatar
Garage: SL Pagoda
Send a message via ICQ to SUPRA
Certainly fun, but I don't think this is the perfect conditions for the M5...
"FIA International Speed Record Holder"
Originally Posted by T Bone View Post
Relax. It is clear the RS6 was faster.
SUPRA is offline
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 01:31
E34 M5 owners weekend (5 till 8 September 2003) raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 5 28th September 2003 09:32
What now - Lexus starting a driving school too? Aussie2U Off Topic Forum 2 25th November 2002 16:34
Great News! Wife hates driving the car! bmurphy E39 M5 and E52 Z8 Discussion 16 2nd April 2002 18:48
SMG Press Release Omar E39 M5 and E52 Z8 Discussion 12 18th February 2001 23:45
Page generated in 0.16760 seconds with 11 queries
