Old 16th November 2002, 07:44   #1
V-10 4 Me
V-10 4 Me's Avatar
Garage: 2001 530i Black
Rhino Ramps for M5
Lastly I would like to inject a little about the ramps. I have found that when utilizing ramps in the garage where the cement is reletavely smooth, one should bolt ramps to garage floor.
Rhino Ramps are made of HD Plastic and can withstand 12,000 lbs ea.! They are also Low Profile to allow most lowered car to drive up.
The way in which i did mine was to allign ramps in front of vehicle where you would like your car to climb up and be positioned at the top part of the ramp. Then located in the front part of either ramp is a 5/8" hole to place a bolt. Once you mark the center of the holes, take a 5/8" cement bit and drill hole as per instructions on the 2 1/2 " Lead anchors. Drop lead anchors in, place Rhino Ramps as positioned above, lag 2 ea. 3" bolts with washer thru ramps into cement and Wah-Lah! Your ramps are going anywhere.
Always take the necessary measures to do the job right and have a happy and safe holiday.
Sam
AS CAI ~ Lo Jack
3 ~ 1/60 ~ M Audio
Do Not Enter---------->///M5---------------------------X
V-10 4 Me is offline
Old 16th November 2002, 09:35   #2
IloveM5s
Garage: hotwheels
If you didn't want them to move, you could have just placed a rug or carpet underneath
IloveM5s is offline
DIY Oil Change instructions Naka E39 M5 and E52 Z8 Discussion 56 20th August 2006 10:05
Page generated in 0.08543 seconds with 11 queries
