Old 5th November 2002, 08:58   #1
rad22
rad22's Avatar
Garage: 2006 M5 Sapphire Black over Sepang
Nav Screen Pinouts
Does anyone have the pinouts for the 2 connectors on the back of the in-dash nav system head unit for the Mk III (female voice) system?
I've already done the surgery necessary as described here, http://www.bmwtips.com/, to use the tape system inputs to provide aux input for my iPod mp3 player, and as suggested, a preamp is required. I just received via internet mailorder, the AudioControl® amp featured in the article. It needs three connections (1. +12V 2. Gnd and 3. Remote on) and I am searching for sources for these in the connectors of the nav screen head unit. I'm open to other knowledge as well for alternative sources for this unit's needs (#1 and #3).
BTW, I HIGHLY recommend this hack. Although without the amp, the iPod and BMW volume must be set to near-max, the sound quality obtainable is absolutely unbelievable. Can't wait to get the amp up and running. With my 20 gig iPod, I have currently over 3000 songs online to hear in the car at 128-192 kbps sampling rates.
Sapphire Black/Sepang Perforated/Olive Ash
rad22 is offline
Old 5th November 2002, 15:24   #2
sysvr4
sysvr4's Avatar
Garage: 2002 M5 (Chairetto Red)
Ground and power should be very easy to fine. Power is usually green and ground is usually brown or brown with black stripe. You can verify this by:
1) Strip each end of a very small gauge (18-22) solid core wire approx. one foot in length
2) Put one end into the hole in the connector corresponding to a green wire (or any wire you want to test for power)
3) Take a volt meter and touch the other end of that wire to a lead from the volt meter. Touch the other VM lead to a ground point. You'll have to find a known ground wire, or make your own. If you just touch to metal on the car it prolly won't work unless you strip the paint off.
4) Once you find power, ground is easy. Move your wire to a hole for a brown or some wire you think may be a ground. Set volt meter to continuity test. Touch one lead to your wire and the other to your known ground. If you have continuity, you found your ground. If not, try another wire.
As for remote, I'm not sure about it in the front of the car. But I know that in the back of the car it's the white wire. You can test for it the same way you test for power above, but you'll have to have at least the accessories on.
Let us know what you find, I may end up having to do this too since Vision totally screwed up my RCA install on my tuner.
Jeff
sysvr4 is offline
Comment & Question about our NAV software for the beast............ FAST 5 E39 M5 and E52 Z8 Discussion 21 24th May 2003 17:58
Can the NAV screen brightness be adjusted and the radio GAL setting?.............. FAST 5 E39 M5 and E52 Z8 Discussion 0 16th February 2003 03:10
upgrading nav and screen software without nav system tfung E39 M5 and E52 Z8 Discussion 10 23rd June 2002 10:47
updating NAV software...very simple, quick, and painless. 6 minutes. Jacob Lee E39 M5 and E52 Z8 Discussion 7 2nd February 2002 16:27
MP3 player - on the NAV screen (TV-AV related) 1C00lVC E39 M5 and E52 Z8 Discussion 19 8th March 2001 01:06
Page generated in 0.11670 seconds with 11 queries
