Originally posted by doug
And so my question wrt Stoneguard is: do I have it applied immediately after delivery while there are no chips, or wait until Spring when the paint has had more of a chance to cure? There's been a lot of discusion about the soft paint, and not waxing/polishing right away. But as someone pointed out, you want to be sure to remove any paint swirls before Stoneguard application.
TIA.
Hey guys, this is my first post on this board. I hope I can contribute.
FamilyM5,
Thank you for the kind words. It was a pleasure working with you.
Doug,
Paint cure is no problem on new BMWs. It is cured more than enough at delivery. I have installed a clear bra on a "special" M3 that was flown over the day it rollled off the line with no problems.
I have seen as many as a dozen chips on the drive from the performance center to my shop, so if you are buying a clear bra, I would do it as soon as possible.
The performance center is very good at not leaving swirl marks. If they did, the clear bra would conceal them.
