Old 4th November 2002, 06:56   #1
scottiedavies
Garage: mazda familia black
OBC Menu
Sorry if this has been posted before, just thought that you might be interested.I found some interesting stuff on the OBC that can be unlocked.
There are two buttons on the e39's instrument panel. The button to the lower left of the speedometer is the reset button (r)for the trip odometer, the button to the lower right of the tachometer is the check control key, (c). When key is in position 1, hold the c button, the check control indicator will read "check control ok" keep holding the button, after a few seconds the screen will go blank and after a few more seconds the indicator will display "TEST-NR 01" There are 21 tests all together.
From here, pressing the c button will change from test to test or holding it down will exit the tests. the r button scrolls throught the options in each test. BUT this may change settings in some tests.
here is the display after each press of the c button for test one.
TEST-NR 01
FGSTNR:GM615xx (VIN serial nuber)
and a few other displays will also follow.
Press the c button to move to test 2, this is fun!!
pressing the c button again will go to test 3, from here the tests are locked. press the r button and the indicator displays "LOCK ON". To unlock press the r button again and the indicator will show "LOCK 00". Add up the last 5 digits of your VIN. this is a number between 0 and 45. use the r button to scroll to that number then press the c button.
to lock these functions go to test 19 and press the r button.
Note that the language that the OBC uses is in german. If you know german, pese tell me what all of the tests are saying.
SMG = Simple Manual Gearbox
scottiedavies is offline
Old 4th November 2002, 10:25   #2
ycchan
Garage: Golf GTI
Heres a link to "exploring your OBC" functions
http://www.ideaphile.com/bmw/540-obc.html
ycchan is offline
Old 4th November 2002, 14:36   #3
Ashok Arora
Ashok Arora's Avatar
Thanks for the post(s) - you learn something new every day.
Ashok
2002 Carbonblack/Caramel
Ashok Arora is offline
Old 4th November 2002, 17:59   #4
greg
greg's Avatar
Garage: 2000 Anthracite
yes, posted before. Very interesting stuff. I've used it recently to check my tachometer calibration, to watch the instaneous fuel flow and the instantaneous battery voltage.
Try turning your headlights on at idle some time - they must draw a LOT of current at start-up so that they achieve brightness as soon as possible - because you'll see the voltage drop well over a volt and then creep back up.
I now know my car idles at 635-645 RPM and that 6th gear is good for 15-20% better mileage at 60mph than 4th. (Not that I was cruising in 4th - just found it interesting to watch this sort of thing.)
greg is offline
E34 OBC Hidden functions BlueBiturbo ALPINABoard.com | BMW Alpina Discussion 26 21st February 2006 13:09
Discovered additional OBC settings MTANG E39 M5 and E52 Z8 Discussion 5 29th November 2005 15:24
TECH: OBC range @ --- and i drove for young-nyc Off Topic Forum 6 16th June 2003 04:50
OBC Menu scottiedavies M5 E39 and E60 tips & tricks 4 19th December 2002 06:00
Woah kinda weird Main menu on NAV young-nyc E39 M5 and E52 Z8 Discussion 0 6th May 2001 05:48
Page generated in 0.10470 seconds with 11 queries
