So a few weeks ago I stumbled upon this thread: Comprehensive MSS54/MSS54HP DME Information
Some of you might know/seen that I already started to attempt to find some of the maps/tables myself.
Our DME has well over 2,000 maps/tables/values but only about 100 need to be altered to make a custom tune.
The MSS52, MSS54, MSS54HP are all remarkably similar, so a lot of the work that has been done on m3forum will carry over.
With the blessing of the p0lar on m3forum I've decided to get the ball rolling over here.
Its quite easy to read/write your DME with a ~$20 cable called the Galletto 1260.
Quite a few others manufacturers' DME/ECU has been cracked and reverse engineered already e.g. Subaru, GM, Mitsubishi, Ford.
If we can map out the DME then any competent tuner will be able to write tunes for us.
So who wants to help out? Who knows how to use WinOLS or Tuner Pro?
Personal note: this is my 4000th post!
