• Latest threads
    • Custom feed
      • Updates
        Old 30th October 2002, 19:21   #1 (permalink)
        Anita
        Anita's Avatar
        Clear coat layer on paint chip touch-ups. Did you use it?
        I 've been following the paint touch-up protocol outlined by Car Care Specialties, Inc. in their car car tips info section that involves applying multiple layers of paint, etc. to a chip reapir. I've completed applying about 8 layers of paint to my 5 hood chips. Two of these chips were acquired on our way home from the purchasing dealership--down to the primer no less! At least I wasn't the only one driving my car that day.
        I think I need about 3 more layers to get a surface that will be decent enough to sand. When doing these repairs have you used the clearcoat paint as your last few layers? Did you use the Finesse Block to remove the raised areas of the repairs or something else?
        My main goal is to seal the surface, especially where the primer is showing, but of course I would like the repairs to look good. Don't ask me what gave me the guts to start painting away on my car, but I felt it was better than having the hood repainted (?) as the body shop had wanted to do, or having a technician or someone else put the dreaded one time touch-up-paint-brush-blob on my car.
        Anita is offline
        Old 30th October 2002, 19:35   #2 (permalink)
        Teutonaddict
        Teutonaddict's Avatar
        Switch to clear...
        Anita-
        Since you've got a good color coat laid down, I'd transition to the clearcoat to bring the level up (and over) the surrounding finish. Then you can sand it down flat.
        I've got some serious stone chips acquired over the 47K miles my Beastmistress has propelled me--I just haven't had the time to do the job. I DID buy a great stone-chip-repair kit from the Eastwood Company (www.eastwoodco.com); it has little micro q-tip applicators, and a 3M finger-sanding disk. Pretty cool.
        One warning, however: these current BMW clearcoat finishes are sh*tty when it comes to chip-resistance, so prepare to repeat this ritual a lot. There was a marked deterioration in finish durability between my 98 E39 540i/6 and my 00 E39 M5. I believe BMW started widespread use of its water-based primer during that interval.
        Anyways, I can now scratch my Carbon Black down to the primer with an inadvertent brush of my keychain, or a light, glancing blow with my wedding band. My 98, on the other hand, looked as good when I sold it after two years as it did when I bought it. I guess that's the price of progress.
        Good luck!
        BOTH SOLD!!
        '00 Carbon Black/Black All-Leather/Sportive
        #101421
        Teutonaddict is offline
        Old 30th October 2002, 19:40   #3 (permalink)
        de Witt
        de Witt's Avatar
        Send a message via AIM to de Witt
        You should be sanding the clear coat (laquer, as it is sometimes called), not the paint. The reason you do so many different coats is to get a layer of paint that is even as possible. With that flat build-up of paint, you can apply the laquer in a same fashion, but it does not have to be as even as the fashion in which the paint was applied:
        - surrounding paint
        = existing clear coat
        # touch-up paint
        * touch-up laquer
        ***<----SAND
        *******<---SAND
        PRIMERPRIMER
        You can use a clay bar, which is less abrasive, in the later stages of the sanding processes.
        {o,o}
        |)__)
        The E28 M5 FAQ
        The E34 M5 FAQ
        The E24 M6/M635CSi FAQ
        de Witt is offline
        Old 30th October 2002, 20:31   #4 (permalink)
        louv
        louv's Avatar
        An excellent tool for applying touch up paint: Insulin syringe. No, really! Find a diabetic friend (or other source of needles...) and load it up about a 1/4 of the way with touchup paint. Then gently apply. It produces tiny, controllable drops.
        Load up another with clearcoat.
        Please dispose of properly. Otherwise they'll wash up on the Jersey shore.
        Oh, and don't poke yourself... unless you want an Imola Red tattoo.
        1989 750iL sadly ignored, but still running
        2000 M5 111,000 miles
        2001 Tundra Hauls Stuff - 66k miles
        2007 Z4 3.0si Coupe Commute toy - 15,000 miles
        2008 Z4 M Coupe On the cover of October Roundel
        2008 Mercedes C350 Sport wife's car
        2009 Ducati Monster 696 toy
        louv is offline
        Old 31st October 2002, 04:01   #5 (permalink)
        atomic80
        M5 Extraordinare!
        atomic80's Avatar
        I bought a set of auto sharp pen which comes in the exact color that you specify. There are a number of different tip sizes available. I've tried it and it works great!
        There even is a clearcoat pen too.
        I have tried the syringe idea too and it works like a charm too!
        Jason
        '05 Range Rover w/mods
        '05 K1200S w/mods
        '07 997TT w/mods
        atomic80 is offline
        Old 31st October 2002, 17:55   #6 (permalink)
        Anita
        Anita's Avatar
        Thank you all very much for the info. Are the paint pens that are refered to the ones sold at paintscratch.com? What is the shelf life of those pens once they are opened? Does the paint get too thick to work with at some point? Thanks for the syringe tip also. I do have some doubts that I will come out of that process unscathed though ( I say this looking at the 2 gouges on my fingers when my cordless screwdriver slipped and at the needle rip on my thumb from doing the hand sewing on my kid's costume) I will give it a try in the future though. I know you need to sacrafice for your M5.
        As for the durability of the paint on my M5, I did talk to BMW NA after I noticed the large number of chips my car was recieving. They said they had no knowledge of any paint quaility problems (this was about June 2002). And when I brought the chip issue to the attention of my "service advisor" he looked at me as if I had sprouted even more horns than I normally do when entering his office and told me my problem was known as "road rash". I'm like, "Yeah, Yeah. I've driven enough cars to know this is unusual and I don't want you guys to DO anything to the car, I just want you to document it to create a paper trail and let BMW know what's going on." Any one else with paint durability issues?
        Thanks!
        Anita is offline
        Old 31st October 2002, 22:40   #7 (permalink)
        Teutonaddict
        Deny! Deny! Deny! ...and then Deny!
        I wouldn't expect them to own up to any diminished quality of their finishes. It took them losing a multi-million dollar class action suit about ten years ago to even get BMW to admit that they had been refinishing new vehicles without informing buyers when the factory paint was ruined in transit.
        They're probably over-sensitized to the liability issue from that experience.
        It was when I toured BMW Manufacturing's Spartanburg factory that I learned about the eco-friendly primer and paint system. Eco-friendly, but user-nasty!
        BOTH SOLD!!
        #101421
        Old 4th June 2003, 20:21   #8 (permalink)
        doug
        doug's Avatar
        Calling Anita....
        Anita,
        How did your paint chip repairs turn out? I am in the same unenviable position right now! I want to do the repairs before I bring the car in for the clear bra thing. Hopefully, I can make the repais so it is not at all noticeable. Oh yeah, did you use the paint pens from paintscratch.com, or a syringe? Thanks.
        2003 M5 Sterling Grey/Black
        V1/StealthOne
        Ultimate Pedals Titanium
        Factory Brake Duct Upgrade
        Supersprint Cat-back race exhaust
        UUC Evo 3 SSK/DSSR/Black Tranny Mounts
        OEM 9.5" rims x 4 with 275/35ZR18 Pilot Sport PS2, racing metal value stems
        OEM MP3-capable CD Changer, Bluetooth (12th Generation), Sirius Satellite radio, DVD Nav 2007.2
        doug is offline
        Old 4th June 2003, 22:12   #9 (permalink)
        MAH
        MAH's Avatar
        Paint Shop Women
        Anita,
        Because you are becoming an authority on the paint subject. Perhaps you could fix my chips if you attend the Concorso in Monterey in August. I'll bring the paint .
        Mark
        MY2001 Imola Red
        Lux. Black Interior
        Painted Calipers,
        Autowerke CAI
        Powerchip Software Upgrade
        Tubi Catback Exhaust
        361RWHP
        425HP and growing!
        MAH is offline
        Old 5th June 2003, 04:37   #10 (permalink)
        Teutonaddict
        I hereby retract my earlier statement....
        I know I said earlier to do the touch-up thing, but since that time I've acquired two new hoods (bonnets). Not the best way to address stone chips, but pretty effective nonetheless!
        Seriously, I've had two unfortunate incidents (one my fault; one not) that required new hoods. The good news is that those nasty stone chips are gone!! And I believe that the local bodyshop does NOT use the same water-based primer that the factory uses, so hopefully it will be more durable.
        I also still have an unused Eastwood paint chip repair kit at the ready!
        If the planets are in alignment, I should get my Beastmistress back on Friday. Yippee!!
        -Dave
        BOTH SOLD!!
        #101421
