26th February 2013, 23:33
#10
Carbon Black E39 M5
R&D can't compare to the overwhelming real world uses accumulated by the M5b community. Oh yes those engineers, guess how many of us had engineering degrees. I wouldn't add spacers for cosmetic reasons, but going wider up front dictates it unless you custom build your rims.
