There, that got your attention!
I took the 5 to Donnington a littole whiel ago ran out of brakes on lap 2 at the end of the main straight. Pedal went all wobbly as something in the disc/caliper/pad department had warped with the heat.
Wasn't a bad trip out though, the 5 certainly does amazing oversteer slides on demand, best was through teh Melbourne loop where, from 1/2 way through the corner all the way up the hill, you can light the rears up and its smoke (and unfortunately tyre wear) city!
A few weeks ago we were holidaying in France and the usual autoroute 'progress' was being applied. After the first slow down from 165 (VMAX it seems) to about 100mph teh brakes were fine, during the 2nd which was just a minute or so later - same distortion feeling - same lack of brakes.
Took it into the dealer last week - they are fitting new engine (at 17000 miles) due to excessive oil consumption, chief technician said (after prompting regarding blocked up brake ducts) "Oh yes, the original spec was with brake ducts but the discs were getting 'overcooled' brakes not being there when drivers wanted them - so they modded out the duct system" - needless to say they will be on the cat when I pick it up.
Clutch: apparently with this special type of pressure plate (sachs self adjusting) there is a run in period which if you dont abide by, will ruin it for life. My clutch is quite soft, big power changes from 2nd to 3rd induce a little slippage, hooligan starts wont light the tyres up at all - just spin the clutch.
Just thought you'd like to know my problems !
