Increased airflow....DO I need a software upgrade?
Gang:
What are your thoughts................
I have stock airboxes, K&N filters and tonight I routed 3in tubing from "Nowak Style" inlets up front to the boxes. Now the car can breath much better.
But do I need to have the Dinan software installed to better take advantage of this airflow?
Manny A (Morristown BMW, NJ)
2000 Carbon Black/Full Caramel
Stoptech Big brake kit(Zeckhausen)
Powerchip Gold 93
Active Autowerkes CAI
Full Supersprint Exhaust w/X pipe
Evosport Diff 3.45 40% Lock up
Autosolutions SSK
KW Coilovers Varient 3
BBS LM w/SO3 and 285 out back
Alot more mods, but can't list all.
Chris, when you remove the bumper to install the air ducts you can see the air horns that lead to the factory airboxes.I hooked up 3 inch flexible hoses from home depot rite to those air horns. I did have to cut those air horns a little to make everything jive, but it works great. Good luck!
Powerchip Gold 93
Autosolutions SSK
Unfortunatly I cut the hose a bit short otherwise it would have hooked up directly to the "intakes". As they sit ny they are right behind it soithe effect is almost the same.
I am going to tak it out and run it now to see how it does.
I never understood this nowack air duct thing... it seems that most people have the airducts or sink drains where the brake duct is supposed to be... shouldn't you guys be opening up the area next to the foglight instead?
__________________ US Spec 2001 E39 M5 - LHD AC Schnitzer
