Going in for the big surgery tomorrow.. rod bearings replacement - BMW M5 Forum and M6 Forums
Like Tree32Likes
Old 23rd January 2013, 03:26   #1
CarbonHan
CarbonHan's Avatar
Garage: 2002 Carbon Black M5
This is it. My beast has accumulated 128k miles recently and on a cold start i'm hearing what sounds like rod knock. ONLY on a cold start though. I've heard it before many many times but every time i would pop the hood to listen it sounded like it was my vanos. I cold started my car while it was parked next to a wall when i was leaving work and i heard the noise again but this time it sounded like the sound was coming from underneath my car. After a little bit the sound disappeared. When i got home i pulled into my garage and revved slowly but i couldn't hear any knocking.
Is it possible to have intermittent rod knock????? I always thought that once rod knock was present, it was always there.
Anyways, I'm scheduled to take the beast in tomorrow after work to get the rod bearings replaced. Qais over at South Bay Autohaus is the specialist i'm entrusting with the work. South Bay Autohaus - Hawthorne, CA
I was going to spend the money i've been saving on a super charger but i figure that a super charger kit is pretty useless without the car. I'll keep you guys posted.
The Beast - 2002 Carbon Black M5
///Stock
CarbonHan is offline   Reply With Quote
Old 23rd January 2013, 03:39   #2
LalaRay
LalaRay's Avatar
Garage: 03 ///M5 Jet Black
Yupppppp. Dont ya hate when that happens
LalaRay is online now   Reply With Quote
Old 23rd January 2013, 04:00   #3
lugnuts
lugnuts's Avatar
Garage: 2002 LeMans Blue M5 _______1979 Trans Am_____
Never heard a rod knock go away when warm, I have heard piston slap on cold start go away when warm and noise from a collapsed lifter when cold go away when warm.
lugnuts is offline   Reply With Quote
Old 23rd January 2013, 07:01   #4
wkd928
wkd928's Avatar
Garage: E39 M5 N500 Oxford green II
Probably good preventative maintenance anyway, consider changing the rod bolts for ARP fasteners if you like as well.
wkd928 is offline   Reply With Quote
Old 23rd January 2013, 07:04   #5
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
There's nothing wrong with throwing parts, PMs at a car you wish to maintain, but have you gotten any second opinion on the diagnosis? Do you have a sound clip??
Old 23rd January 2013, 07:28   #6
bmwMcrzy
bmwMcrzy's Avatar
Garage: 02 Le Mans Blue / Caramel DINAN S2
Best of luck and please post pics of the bearings to see how much wear they have @ 128 K
bmwMcrzy is online now   Reply With Quote
Old 23rd January 2013, 07:29   #7
Themightyzeus
Themightyzeus's Avatar
Garage: M5 sliver
This is getting out of hand with scare of rod bearing failure.People hear a slight knock and panic,it must be the vanos making that sound.I would not crack that motor up unless your for sure it's rod bearing failure!!
Themightyzeus is offline   Reply With Quote
Old 23rd January 2013, 07:44   #8
CarbonHan
CarbonHan's Avatar
no sound clip but i'll definitely get one tmrw when i leave work.
The plan is to drop off my car tomorrow night at the shop and have Qais check for rod knock thursday morning along with everything else i want him to. Even if he finds that my rod bearings are fine im going to have him change them anyways.
EDIT: I took a sound clip after work today. Sorry for the bad quality.
Old 23rd January 2013, 07:52   #9
CarbonHan
CarbonHan's Avatar
i didn't know what piston slap was until you mentioned it. I saw a couple of videos on youtube featuring 'piston slaps' in GM cars and the noise i hear from my car on a cold start doesn't sound like that. I guess i'll find out once and for all tomorrow where all my engine noise is coming from.
Old 23rd January 2013, 08:00   #10
CarbonHan
CarbonHan's Avatar
at 128k miles and a super charger in the near future i'm glad to have found a specialist i can trust to change out my rod bearings. When people super charge their beast they usually spend a significant amount of money on 2 additional items:
1) BBK
2) Clutch/FW
Im just adding a third:
3) Rod Bearings.
And i've been on this board since 08. If YOU think you've read too many rod knock threads imagine what i've been going through the past 4 and a half years
Rod bearings beware gixxeridaz E39 M5 and E52 Z8 Discussion 141 28th June 2012 20:05
Rod bearings! Am I paranoid! swight E39 M5 and E52 Z8 Discussion 55 26th May 2012 14:06
S62 engines - big end bearings/rod bearings sam1977 E39 M5 and E52 Z8 Discussion 2 27th October 2011 01:40
Another set of rod bearings.... vantaam5 E39 M5 and E52 Z8 Discussion 82 20th July 2010 11:53
Rod bearings? Lantz E34 M5 Discussion 9 16th March 2010 14:32
