14th January 2013, 17:15
#9
Carbon Black E39 M5
I deal in style 65 wheels ALL THE TIME, the going rate for a set of no story rims will go for $1000. Tires add little value bc they add shipping cost and M5 owners are anal about what is put on the car.  occasionally you'll see rims go for cheap, they're either reconditioned or seller is in a bind.
