Changed stat-coolant leak and part left over - BMW M5 Forum and M6 Forums
Like Tree2Likes
Old 31st December 2012, 01:50   #1
manualshifter
manualshifter's Avatar
Garage: M5 e39
Changed Stat yesterday, had an alloy washer left over- any idea where it's from?
Coolant dripping from bell houssing after test drive...
Guess I have to start over..damn.
Allan
manualshifter is offline   Reply With Quote
Old 31st December 2012, 05:01   #2
caspian65
caspian65's Avatar
Garage: '02 LeMans Blue M5
Did you remove the drain plugs from the block? Looks like the metal washer used for those.
caspian65 is offline   Reply With Quote
Old 31st December 2012, 06:25   #3
manualshifter
Garage: M5 e39
No, didnt get that far, was about to change coolant when I saw the driipping from the rear of engine.
After stat change I Topped up lost coolant with de mineralised water, was going to change coolant when sure I was leak free..
Didn't take plenum off either.
What a pain, had to set off on 500km roadtrip today in the Lexus... z.
Old 31st December 2012, 06:36   #4
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
Crush washer for the 4 way temp sensor, #12 here. RealOEM.com * BMW E39 M5 Waterpump - Thermostat
The Following User Says Thank You to bimmerule For This Useful Post:
manualshifter (31st December 2012)
Old 31st December 2012, 06:37   #5
caspian65
caspian65's Avatar
You most likely ripped an 0-ring on installation.
That ring washer could possibly be the seal for the temp sending unit on top of the t-stat housing...
The Following User Says Thank You to caspian65 For This Useful Post:
Old 31st December 2012, 06:47   #6
manualshifter
Garage: M5 e39
Thanks guys for your ideas, there was a smaller gasket on the temp sender, that I had to sort of unscrew off the threads to put on the new one, could there have been a bigger one as well? I have just done a complete blank on where it came from...
Old 31st December 2012, 16:47   #7
liquidsmoke
Garage: 2001 E39 M5, ACS, Imola Red
You most probably nicked the new o-rings for the TStat housing. I went through a few before I realizes BMW were giving me the wrong size O rings! I ordered some nitrile ones in the correct size from another supplier and no more probs.
liquidsmoke is online now   Reply With Quote
Old 1st January 2013, 00:32   #8
Lunker325
Lunker325's Avatar
Garage: 02 Sterling Grey/Silverstone
Sales Feedback: (7)
+1, thats the crush washer for the 4 way temp sensor. Like others said, you most likely cut an o ring when installing the new stat. Dont worry, it gets easier each time you do it!
12th Gen Bluetooth * Intravee II, Alpine KCA-420i, Alpine TUA-T550 HD Radio * Alpine SPX-17 REF 6.5" F & SPS-500 5.25" R Speakers * OEM Sirius * JL Audio XD600/6 6 Channel Amp(DSP Removed) * Audio Control DQXS * Custom ED Sub Box with 2 x SQ10's * Infinity 611a Sub Amp * Dinan Exhaust * Powerchip MAF-less tune * E60 SSK * ZHP Illuminated Shift Knob * Jet Black Rear Valance * Headlight Armor light smoke tinted tails * 18x10 SSR GT3 wheels F&R * Euro Hella Headlights * Predator Ice AE's with 5W Luxeon K2 Star and 1000 mA PowerPuck Driver * Seasonal OEM Heated Steering Wheel Retrofit * F & R Illuminated Door Sills * Ultimate Pedals * Full Interior LED's * 6000K HID Fogs * MKIV Nav * Passport 9500ci * Griots Italian Air Horn * Slimm's leather tilting armrest * Dinan Stage 1 Suspension *...
Lunker325 is online now   Reply With Quote
Old 1st January 2013, 01:00   #9
MINIz guy
MINIz guy's Avatar
Garage: 00 Jet Black M5
Lube them o-rings up with Vaseline!
I could probably get a tstat out in 20 minutes depending on how tight it is sealed to the engine block. The most time consuming step is draining the coolant, or in my case, pumping it out from the expansion tank.
MINIz guy is online now   Reply With Quote
Old 1st January 2013, 01:57   #10
M5 Sydney
Garage: '99 M5 Carbon Black / Black & Red, 2000 540i Biarritz Blue Metallic, BMW K1200GT Orient Blue, BMW K1 Red / Yellow
There should only be the one crush washer with the temp sensor. I just changed mine and have the old one so will have a quick look. So not sure what your left over part could be?
If you find the source of the leak it may tell you, but it does sound like a nicked o-ring, it's super easy to do. See if you can feel around the back around the three pipes if there is moisture or even a bit of o-ring that was trapped and protruding.
Also, I'd suggest using KY Jelly on the o-rings if you do need to re-insall, water based lubricant is better for their long term life from what I've heard : )
PITA that this happened just before you head of on a road trip!! It's always the way...
M5 Sydney is offline   Reply With Quote
advice on draining coolant for stat change. jamiepeers E39 M5 and E52 Z8 Discussion 23 22nd April 2012 18:00
Changed stat.. still running cold? pyro225 E39 M5 and E52 Z8 Discussion 6 6th November 2010 23:40
Chasing a Coolant Leak - Part One Jboud8880 E39 M5 and E52 Z8 Discussion 10 18th April 2009 17:09
Low Coolant Temp:3rd T-stat, 2nd in 6 months Dan in Seattle E39 M5 and E52 Z8 Discussion 1 2nd November 2008 15:42
Coolant leak advice, seems to be back left of engine bay IvanDias E34 M5 Discussion 25 7th December 2007 19:42
