Washer Fluid - BMW M5 Forum and M6 Forums
post #1 of 15 Old 30th August 2002, 03:53 PM Thread Starter
krullshards
krullshards's Avatar
Question Washer Fluid
The M5 has a regular washer fluid reservoir and an intensive action fluid reservior. I was curious about this and asked my dealer about the intensive action fluid. They said that it is just regular fluid at a higher concentration. They said the BMW used to make a special intensive action fluid back in the day but have not made that for like 5-6 years. Is this true or do the folks at my dealership not know what their talking about?
--Kamran
'02 Sterling Gray M5
MB Quart QSD 215's in the front
MB Quart Premiums in the rear.
JL Audio 13W7 Subwoofer
Two JL Audio 300/2 amps for left/right fronts.
One JL Audio 300/4 for the rears.
One JL Audio 1000/1 for the sub.
Custom enclosure lined with matching Alcantara fabric.
Upcoming:
Nav-Tv
krullshards is offline
post #2 of 15 Old 30th August 2002, 05:41 PM
stever
the dealer took an order for the concentrate and it never came, then he told me to just use more concentrate in the high-intensity container
stever is offline
post #3 of 15 Old 30th August 2002, 06:01 PM
MikeNJ
I was going to start something on this. Not much rain around here lately - so not much window washing. But the other day I used it for essentially the first time.. and when the headlight washer came on there was some weird white substance.. almost grease like.. that ended up over the headlights and hood. Strange! i started to wonder if this was the "intense" stuff, which I could definitely live without!
MikeNJ is offline
post #4 of 15 Old 30th August 2002, 06:25 PM Thread Starter
krullshards
Weird, I've never paid very close attention to my headlight washers or something. I'll have to take a look..
--Kamran
Upcoming:
Nav-Tv
post #5 of 15 Old 30th August 2002, 07:05 PM
Digi
Digi's Avatar
I have ordered and received both the regular and intensive windshield washer fluid. It is in the Accessories catalog, and the parts guy should be able to easily look this up, if they cared. If they won't provide any customer service, ask them for the accessories catalog and show them what you want. IDIOTS!
Digi is offline
post #6 of 15 Old 30th August 2002, 07:22 PM Thread Starter
krullshards
I knew it! Thanks for the info.. Might you know the part number? I can just ask for that part number directly.
--Kamran
Upcoming:
Nav-Tv
post #7 of 15 Old 31st August 2002, 06:48 PM
Digi
Digi's Avatar
BMW Windshield Washer Concentrate
82 14 1 468 858
BMW Intensive Windshield Cleaner
82 14 1 468 859
Digi is offline
post #8 of 15 Old 1st September 2002, 01:15 AM
ThemisN
ThemisN's Avatar
Is it just me or wouldnt we all be happier WITHOUT headlamp washers? I mean, in the end, most of us keep our car clean (ie weekly wash or so at the minimum), and all the headlamp washer does is drive us crazy when it gets the fluid all over the hood and you are FORCED to wash it just so the car doesnt look good.
If and when I go back to a car with them, the first thing I will look for is a fuse or something that would turn it OFF!
ThemisN is offline
post #9 of 15 Old 1st September 2002, 02:11 AM
DZeckhausen
DZeckhausen's Avatar
It's easier to do this than you might think. In fact, you could convert the headlight washer to manual only operation.
The headlight washer is software controlled. Every 5th time you use your windshield washer, a ground signal is applied to the blue/black wire that goes to pin 9 of your headlamp washer module. To disable the headlight washer completely, snip the wire. To make it manually controlled, cut the wire and reroute it through a switch. Pin 8 (brown wire) on the washer module is the ground, so you can use a momentary contact switch to short these two pins together.
You could even get clever about it and buy a BMW switch from the early E39 ASC control. Then you would have an "Auxiliary Squirt Control" button!
Credit for the ASC switch idea goes to Jim Cash from the Roadfly board.
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed (Sold)
StopTech 4-wheel big brake upgrade (ST-60 front/ST-22 rear)
M5 Front Swaybar
CDV Deleted (of course!)
2012 BMW 328i Luxury Line
StopTech 4-wheel big brake upgrade (ST-60 front/ST-40 rear)
2015 BMW X1 xDrive28i M Sport
xDrive35i brake upgrade
DZeckhausen is offline
post #10 of 15 Old 1st September 2002, 03:53 AM
MAVERICK
MAVERICK's Avatar
MAVERICK is offline
Help!! dealer puts wrong washer fluid? beewang E39 M5 and E52 Z8 Discussion 8 27th September 2003 11:06 AM
Filled in wrong fluid in the servosteering DrSakke E34 M5 Discussion 5 20th October 2002 11:19 PM
Electical bugs and the fix (washer fluid) BimmerBoyM5 E39 M5 and E52 Z8 Discussion 3 8th July 2002 03:37 PM
factory washer fluid tfung E39 M5 and E52 Z8 Discussion 10 18th March 2001 08:10 AM
