Old 19th August 2002, 21:31   #1
M'nd
Guest
M'nd's Avatar
Garage: 2002 M5 Carbon Black
No M-Mobility kit
Just looked in trunk and saw no m-mobility kit, the salesman said the car has run flat tires which posts here seem to contradict.
Is the m-mobility kit right in front of the battery case? In my car that spot is empty. I have golf clubs in my trunk right know so i could not lift the carpet up to see all the way to the backseat.
This is a 2002 model delivered in July. Could the car have run flat tires now?
M'nd is offline
Old 19th August 2002, 21:45   #2
krullshards
krullshards's Avatar
Garage: '02 Sterling Gray M5
Send a message via AIM to krullshards
My '02 was delivered in Oct last year. I had the kit. You have to lift a couple panels before you get to it though. You SHOULD have it.. I haven't read anything anywhere of the cars being sold with run flat. What type of tires did yours come with? I've heard of them either having Dunlop's (like mine) or Michelin Pilot Sports. If they are the Michelins I believe the Michelin run flats have a "ZP" designation on the tire side wall (for example: Michelin Pilot Sport XGT Z4 ZP). It looks like Dunlop's say "DSST" on their run flat tires.. So look for those designations on your tires to tell if your dealer knew what he was talking about. BTW - Which dealer did you go to? Passport?
--Kamran
MB Quart QSD 215's in the front
MB Quart Premiums in the rear.
JL Audio 13W7 Subwoofer
Two JL Audio 300/2 amps for left/right fronts.
One JL Audio 300/4 for the rears.
One JL Audio 1000/1 for the sub.
Custom enclosure lined with matching Alcantara fabric.
Upcoming:
Nav-Tv
krullshards is offline
Old 19th August 2002, 21:45   #3
Diamond Dave
Diamond Dave's Avatar
Garage: 2000 Ford Expedition
M,
This doesn't sound right to me at all. If BMW were going to use run flats on our cars, this board would know about it. Don't think I've heard mention of this at all.
Go on home and take out the golf clubs. The next instruction is extremely important: Grab a Corona and place it in the freezer. Head back out to your beast and remove the netting and trunk cover. The M Mobility System should be right there in the middle.
Next, go get the beer and your phone and let the salesman know that he's ignorant about the E39 M5! Please let us know the outcome.
Good luck and welcome to the board. You have great taste in cars.
DWP
Diamond Dave is offline
Old 19th August 2002, 21:47   #4
M'nd
Guest
M'nd's Avatar
Thanx for the help guys! I'll get this worked out. I bought the car at VOB BMW in Rockville, MD.
M'nd is offline
Old 19th August 2002, 21:53   #5
krullshards
Hey, no problem, just doing my part. Hehe.
Old 19th August 2002, 22:03   #6
atomic80
M5 Extraordinare!
atomic80's Avatar
Garage: 2007 Cobalt Blue Porsche 997TT
FYI, to the best of my knowledge only the Z8 comes with run-flats.
Jason
'05 Range Rover w/mods
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 19th August 2002, 22:04   #7
khiroshima
khiroshima's Avatar
Garage: 2001 M5 silver
Yes, you might want to double check. I originally thought I did not have one also, but I stared at the picture and finally figured out what compartment they mean. Yes, it is in front of the battery, under some other stuff . . . Kevin
khiroshima is offline
Old 19th August 2002, 23:46   #8
JFB
JFB's Avatar
Garage: 2001 M5 Royal Red / Caramel / Burl
Tom Salkowsky commented at the BMWCCA dinner here in July that BMW does not install run flat tires on the ///M cars. (Note before replying: the Z8 is not technically an ///M car.)
BMW reportedly does not think the current run flat tires are suitable for high performance driving. Tom did say that more and more manufacturers are moving to the use of run flats, and that BMW might eventually install run flats on ///M cars when the tires are sufficiently well designed.
As noted above, to find the im-Mobility kit (pun intended), you'll have to pull out the foam panels under the trunk liner, forward of the battery.
Jim
2001 ///M5 Royal Red / Caramel
JFB is offline
Old 20th August 2002, 03:43   #9
MJ
MJ's Avatar
Garage: 2008 Space Gray M5
Your salesman is an uninformed idiot. Sorry to be blunt, but that's what I do for a living.
MJ
'02 Sterling/Black Lux
MJ is offline
Old 20th August 2002, 03:47   #10
Digi
Digi's Avatar
Garage: 2006 M5 Silverstone II
It is not directly under the trunk cover in mine, you must also lift out some styrofoam as well to see into the bottom of the well. No way BMW has started installing run-flat tires yet.
Digi is offline
new brembo 380mm kit tfung E39 M5 and E52 Z8 Discussion 13 9th August 2003 03:00
Bluetooth kit and Sirius available for older E39's this September? ngc5904 E39 M5 and E52 Z8 Discussion 4 27th April 2003 18:46
StopTech E39 4-Wheel brake kit details DZeckhausen E39 M5 and E52 Z8 Discussion 26 20th March 2003 07:11
TECH: "M" blow me kit VanCooper E39 M5 and E52 Z8 Discussion 25 12th May 2002 21:30
470HP kit and 500HP kit due soon! Quad_exhaust E39 M5 and E52 Z8 Discussion 32 24th March 2002 00:55
Page generated in 0.14604 seconds with 11 queries
