I just installed the voice recognition module. A couple of suggestions for the mechanically challenged (like me):
1. the blue connector may have a jumper on it. The jumper looks exactly like the blue connector on the top of the VR module. The actual connector is the top part- the part connected to the cable. This part has a white u-shaped lever. If you move it down, away from the cable, it allows you to pull out the connector from the jumper. Once you insert the connector into the VR model, reverse procedure and move white lever up to lock connector into VR module.
2. The bracket can best be installed if you remove the CD player (not the NAV player on top, but the music player in front). You can do that by unscrewing the 2 phillips screws on the right side of CD player (the side facing the passenger compartment). Then lift and pull the CD to release it from the mounting bracket on the left side...no need to unscrew anything there.
3. The mounting bracket mounts on 2 stems (bolts) already in place - just insert onto stems and attach nuts. Then mount VR module, and reattach CD player.
4. Once all is back together, hold down "speaking man" button on steering wheel for a few seconds and you'll hear female voice and see "Voice Recognition" displayed on dash (where you normally see the computer messages that you can toggle through by pushing end of stalk on left side of steering wheel).
5. Say "Dial number"; wait for female voice to prompt you to say number; say 3 or four numbers (she'll repeat and put on display where the words "Voice Recognition" appeared), when finished number, say "dial number" again.
6. Question: how do you program names in phone book? I got as far as putting in name and phone number, but you must then say something to actually fix it in program. When I tried to use programmed name, voice said "phonebook empty".
