Old 13th August 2002, 17:01   #1
Diamond Dave
Diamond Dave's Avatar
Garage: 2000 Ford Expedition
Turn Signal Dilemma
Guys,
The wife has been complaining about her driver's side turn signal acting funny and this past Sunday while I was in her X5, it happened to me.
You activate the turn signal and get the fast blinking which means that a bulb is out. Walking around the car I see it's the turn signal bulb up front in the Xenon headlight assembly (which conversely looks like a ***** to get to).
Here's the odd part - it only does the fast blinking in the morning when the car is cold! Drive it somewhere, park, take care of a few errands, get back in and the turn signal works just fine! I'm stumped!
Any ideas? Could this mean that the bulb in question is about to go? The car has always been garaged and we've had little rain here in Texas this summer so it's not a question of moisture.
Thanks in advance!!!
DWP
Diamond Dave is offline
Old 13th August 2002, 17:07   #2
Roton
Roton's Avatar
Garage: '01 Anthracite/ Black Luxury
Sounds like a wire or socket connection problem to me.
///M Trunk Mat
///M Valve Caps
Valentine One
Screaming wife
Roton is offline
Old 13th August 2002, 17:20   #3
TCM
TCM's Avatar
I agree with Roton. Sounds like a bad connection. Maybe it has something to do with the metal expanding and making a contact when the car gets warmed up? Either way, you should look into replacing the bulb or at least investigating the situation a little more. Good luck.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 13th August 2002, 22:00   #4
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
I remember reading a post (which I canīt find now...) a while ago about the same problem. That was due to a bad connection between the wire and the lamp connector, not between the lamp connector and the bulb.
David
DavidS is offline
Old 13th August 2002, 23:00   #5
nt
nt's Avatar
Garage: '01 M5 Silverstone
Exactly the same thing happened to me, except eventually it stopped working completely. Took it in (no appointment), the service tech changed the bulb while I waited. He said the bulbs often go bad like that.
You can change the bulb just by reaching in and pulling, but it's extremely tight. I would let the dealer do it (it's under warranty).
This was on an M5 not an X5 though.
Nick
nt is offline
Old 15th August 2002, 02:02   #6
Teutonaddict
Teutonaddict's Avatar
Garage: '00 Carbon Black/Black All-Leather/Sportive
Been there....
I, too, experienced the intermittent double-time on my driver's side blinker. During last instance, front bulb appeared burned out.
B/c I was doing some work on my xenon angel eye unit (long story), I pulled out the whole assembly and removed the whole bulb. The filament was in-tact, so I reinstalled and it resumed operation. For all of half a day.
I then assumed it was the side-marker light, since the front large bulb worked. I took her to the dealer, after the parts department told me on the phone that the porters could replace the side-marker bulb right there in the drive-up lane. LIE, LIE, LIE.
It's more challenging than that. BUT, they ended up replacing both the side marker bulb and front small bulb at the same time, all under warranty (at 43K miles).
All better now!!
-Dave
BOTH SOLD!!
#101421
Teutonaddict is offline
Old 15th August 2002, 02:58   #7
KrazyKidd
KrazyKidd's Avatar
Garage: '02 Black Saph-Met 530i
Send a message via AIM to KrazyKidd
This happened a few days ago on my rear ones so i took it out and had a look at it. The bulb was fogged up and looked like it blew. But it still worked sometimes. It was weird but I decided to replace it myself anyways. The problem has since vanished.
My Opinion: Replace bulb and all should be good.
KrazyKidd is offline
Old 19th August 2002, 17:47   #8
Diamond Dave
Fixed!
Hey Guys,
Thanks for all the help and suggestions. It was in fact the bulb. Interestingly enough, it wasn't foggy nor was either of the two filaments blown. Rather, it was the exposed wire at the bottom of the bulb connector that had somehow fried.
The tough part of this repair was getting to the turn signal wire on the front of the X5. I literally had to remove the four screws holding in the Xenon headlamp assembly and then slide it forward to gain access. Once that was accomplished, a quick trip to the dealer and $7.00 later, problem fixed.
This board rocks!!!
DWP
Old 19th August 2002, 18:00   #9
krullshards
krullshards's Avatar
Garage: '02 Sterling Gray M5
Send a message via AIM to krullshards
One thing to keep in mind... I had my driver's side turn signal bulb go out on me. It was wierd because my car was only a few months old (will be a year this Oct). Also the bulb seemed in tact. I noticed at the base of the bulb it looked kinda blackened. I took it in and it turned out they had to replace the wire/socket because it had somehow shorted and melted the bulb's connectors. It was odd, but make sure your socket is not shorted out or something. Mine's also was on an M5 though so... I dunno. My current problem is my PDC being dead. Have an appt on the 28th though.. Sigh..
--Kamran
MB Quart QSD 215's in the front
MB Quart Premiums in the rear.
JL Audio 13W7 Subwoofer
Two JL Audio 300/2 amps for left/right fronts.
One JL Audio 300/4 for the rears.
One JL Audio 1000/1 for the sub.
Custom enclosure lined with matching Alcantara fabric.
Upcoming:
Nav-Tv
krullshards is offline
Old 19th August 2002, 18:27   #10
Diamond Dave
Kamran,
Thanks for the heads-up. If the bulb blows anytime soon, I'll take the car in armed with what happened to your M5. It's still under warranty and I'll let the dealership fix it.
Sorry to hear about your PDC. Hopefully, it's something simple!
Take care and good luck,
DWP
Okay, how do you get the side turn signal lenses off? SouthshoreM6 E39 M5 and E52 Z8 Discussion 3 25th April 2003 17:42
How too change the front turn signal bulbs? Micsor/DK E39 M5 and E52 Z8 Discussion 2 29th March 2002 17:34
How too change the front turn signal bulbs? Micsor/DK Off Topic Forum 0 29th March 2002 09:17
And yet, more pics from Sears Point PhilSeastrand E39 M5 and E52 Z8 Discussion 6 21st August 2001 04:17
Page generated in 0.17147 seconds with 11 queries
