Yellow engine light, two codes: 105 and 170, advice please - BMW M5 Forum and M6 Forums
Old 23rd August 2012, 18:51   #1
swight
swight's Avatar
Garage: E39 M5
Hi, I have just got the yellow engine light for the first time. I pulled the codes and they are:
Code 105: Plausibilisierung Motortemperd
Code 170: Sekundaerluft Mindestdurchfluss
Sorry for my poor German! The first code I reckon must be the engine temp. It has had a new thermostat recently so could that be the temp sensor. If so does it have two, one for the gauge and one for the ecu?
And is code 170 for the secondary air flow system?
swight is offline   Reply With Quote
Old 23rd August 2012, 18:57   #2
Clayton Usher
Clayton Usher's Avatar
Garage: M5, Silverstone Metalic, 2000
170 is for the Secondary Air flow, a common fault on E39 M5s, but shouldnt trigger EML..
105"Engine coolant temperature, Plausibility", has it overheated ??
Have you looked in the OBC to check the water temp ? loads of useful threads on this
Clayton
Clayton Usher is offline   Reply With Quote
Old 23rd August 2012, 19:01   #3
swight
swight's Avatar
Garage: E39 M5
Hi, thanks for that. Its never overheated, temp gauge is at 12 o'clock. I will check the temp with the OBC thanks
Old 24th August 2012, 09:25   #4
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Unplug the Temp Sensor (It is a double temp sensor, all in one) on top of the T Stat Housing, inspect and re connect.
Get your Secret Menu Option 7, sub menu 1 up on your instrument cluster and then go for a cruise at 50 mph in 6th and report back the lowest temps you see..(However this test is not so stringent in the the summer months).
Have you ever checked your codes previously ?
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
The Following User Says Thank You to M5 London For This Useful Post:
Sailor24 (24th August 2012)
Old 24th August 2012, 19:27   #5
swight
swight's Avatar
Garage: E39 M5
Hi, I have just pulled the plug on the temperature sensor and cleaned with contact cleaner.
Been for a drive and got her fully warmed up. At 50mph in top gear she is reading 85 degrees C, when I push her she goes up to around 90 degrees, then settles back down round 85.
This was the first time I have read the codes. I also cleared the codes. No engine light as yet.
Old 25th August 2012, 12:29   #6
M5 London
M5 London's Avatar
Cool !!
Keep us posted.
swight (25th August 2012)
DSC light and yellow "brake" light came on. NO ABS light. timmay77 E39 M5 and E52 Z8 Discussion 33 16th February 2013 19:54
Yellow engine warning light came on... Larry's M5 E39 M5 and E52 Z8 Discussion 29 18th October 2009 06:50
Yellow Engine warning light after 700+ mile "Eurohoon" m5fishin E39 M5 and E52 Z8 Discussion 5 6th August 2008 23:18
Yellow Engine Light - What does it mean ? skyloon E39 M5 and E52 Z8 Discussion 9 17th December 2007 22:05
What do Production Codes in the 170's mean? afdeluca E39 M5 and E52 Z8 Discussion 2 28th January 2003 15:44
