ZKE trouble code 80 and 81, Bad servomotor? - BMW M5 Forum and M6 Forums
Old 22nd August 2012, 04:46   #1
68FB
Garage: 2001 M5 Ti Silver
I have the two trouble codes 80 and 81 in the ZKE module shown below. They come back immediately after clearing. Anyone any idea what this servomotor is? I tested all the ZKE/GM3-controlled motors listed in the attached PDF and they all work, except I couldn't test the servotronic valve on the p/s box. I replaced that a year or two ago because of a 74 code, but it could have gone bad again because the steering has been feeling a bit heavy lately. Any ideas?
M5 ZKE III Module Manual.pdf
68FB is offline   Reply With Quote
Old 22nd August 2012, 15:02   #2
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Servo -valve sorry no idea. If it makes you feel better I have some body codes too that I cant figure out. One is my sunroof switch it works well and appears fine but I get a code for it. There are one or two more that I have and tried to figure out but nothing appears wrong. I will check if it is those codes.
I believe servotronics is the door locks?????
Sailor24 is offline   Reply With Quote
Old 22nd August 2012, 15:10   #3
rao
Garage: Silver 540i
This might be useful:
Hard/heavy steering - possibly GM? - Bimmerforums - The Ultimate BMW Forum
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is offline   Reply With Quote
Old 22nd August 2012, 23:48   #4
68FB
Excellent thread, rao. Thanks. It confirms 81 is for the servotronic solenoid valve on the p/s box. I'll check the wiring first then replace it (again). It does make the car much more pleasant to drive.
I wondered why I was getting a solid code for a short circuit AND a solid code for an open circuit, but I see from WDS it gets two 12V supplies. I guess one is shorted and one is open which makes me think the problem is internal to the valve
Name:  Servotronic valve - WDS.JPG
Old 23rd August 2012, 00:07   #5
rao
Garage: Silver 540i
Glad it helped
Old 23rd August 2012, 00:40   #6
Sailor24
Sailor24's Avatar
I think I see what is going on with your aux fan. I see a 1E auc sensor. Not sure exactly what that puppy does but it certainly is sampling air coming out of the shroud.
Old 23rd August 2012, 04:45   #7
68FB
That AUC sensor is an obscure one that somehow senses pollution coming into the cabin and puts the HVAC into closed loop, if you have the option. It doesn't look like it has anything to do with the aux fan.
what is the AUC sensor?
Old 23rd August 2012, 05:46   #8
Sailor24
Sailor24's Avatar
Carbon Monoxide sensor who would have figured? Now that I know what it does I will use it.
Google Translate
AUC sensor location
Purpose of the Sensor F. Auc - Bimmerfest - BMW Forums
Google Translate
The Following User Says Thank You to Sailor24 For This Useful Post:
68FB (24th August 2012)
Trouble with error code, need help! Galant turbo E39 M5 and E52 Z8 Discussion 24 17th May 2013 23:04
E39 M5 Trouble code mystery Dex1 E39 M5 and E52 Z8 Discussion 19 21st October 2008 16:24
Anybody using a Generic code scanner? Trouble getting a reading. jfman E39 M5 and E52 Z8 Discussion 0 7th July 2008 06:24
Trouble reading code vabchbmw E39 M5 and E52 Z8 Discussion 3 17th August 2007 22:57
Trouble Code Question (Long) x703jko E39 M5 and E52 Z8 Discussion 0 24th May 2004 06:57
