I'm in a real pickle - need advice - BMW M5 Forum and M6 Forums
Like Tree3Likes
Old 20th August 2012, 18:55   #1
mattmor
mattmor's Avatar
Garage: 2000 M5 Carbon Black
I was in the middle of doing a new water pump, thermostat, belt tensioners etc. when I snapped off one of the hex bolts for the water pump. It's #5 on the realOEM diagram which goes in the top hole of the water pump. I came back with the bolt and about 2 threads on the end leaving the rest of the bolt back in the block. Chances are that I over torqued the bolt going back in, but I wasn't giving it much so it could have just been brittle.
I'll probably have to remove whatever is between the water pump and the block where the threads are in the back. (Vanos, timing?) Then use the standard broken bolt removal tricks with a drill bit and easy out. Perhaps, someone with a lot more experience can point me to some of the DIY threads that can help me get to where I need to be and also whatever advice that might be useful when working on this. I'd really appreciate it. I'll post some pics of the broken bolt and point out the area of the engine in question when I get home.
mattmor is online now   Reply With Quote
Old 20th August 2012, 19:45   #2
m5 deamon
m5 deamon's Avatar
Garage: 2003 e39 m5 carbon black on black sport interior
did you get the bolt out
2003 m5 Carbon Black, Black sport interior,
Evolve stage 3 Alpha N with power tune buh bye pc93 tune
Evolve cold air intake
Evovle heads with shrick cams
Raikku Modded Throttle Bodies
SS Headers going to make the jump to evolve headers real soon as soon as a certain some one on this board buys them lol you know who you are!
Zionsville Radiator with spal 2 speed fan
UUC Light Weight Fly Wheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmission mounts
Steel braded clutch line
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braided brake lines
Dinan rear sway bar
Dinan rear stress bar
Custom built M5 front stress bar
Tc sway bar brackets
Stop tech St 40
Kw v3 suspension
Rouge blue control arms
Ground control camber caster plates
L I custom Adjustable sway bar links front and rear
Predator ice v3 angel eyes
Bimmian black kidney grills
VVME xenon 4300k fog lights
Solaris amber bulbs
led lic plate lights
Exotics tunning rear cf finned diffuser
Vorsteiner front splitters
v1 hardwire
m45 blinders updated version
Slimbones xl foglight covers
Euro tail lights with rear fogs hooked up
Bsw Stage 1 with there subwoffer package
Alcanterra shift boot and ebrake boot from leather z
Alcanterra ebrake handle from a m3 csl
Illuminated zhp shift knob
Alcanterra custom wrapped steering wheel
Custom interior orange led in door pockets and handles
To Come... Evolve headers and race cats, this list seems to be shrinking!
m5 deamon is offline   Reply With Quote
Old 20th August 2012, 19:51   #3
mattmor
mattmor's Avatar
Here's some pics of what I'm looking at.
Old 20th August 2012, 19:54   #4
mattmor
mattmor's Avatar
Only thing left is the threaded part of the bolt that broke off inside. Everything else came out that's in the picture above.
Old 20th August 2012, 20:02   #5
gzig5
I would start by getting a good quality 1/8" aircraft drill (usually about 6" long) and wrap electrical tape around the shaft in two places along the shaft to build up the diameter to just under the diameter of the hole through the water pump. This will center the drill bit in the bore and should allow you to start a pilot hole fairly well centered in the remnant of the bolt. All you need is a shallow hole at this point. Then you'll have to remove the pump and see where you go from there. An easy out and some heat applied to the block around the hole may be enough or you may end up drilling it out. I suggest this because getting a hole to start in the middle of a broken bolt can be a challenge.
_____________
Dinan 3.45 Differential
Evolve Tune
Dinan Rear Sway Bar
E60 545 SSK
275's on OEM 9.5" all around
gzig5 is offline   Reply With Quote
The Following 4 Users Say Thank You to gzig5 For This Useful Post:
Adam_E (21st August 2012), bibledriver (22nd August 2012), mattmor (21st August 2012), Sailor24 (21st August 2012)
Old 20th August 2012, 20:25   #6
mattmor
mattmor's Avatar
Hell of an idea. Where can I get one of these aircraft bits?
DIY: F10 Shifter Knob and Boot Install
Old 20th August 2012, 22:11   #7
gzig5
Ace Hardware or maybe Home Depot usually has long ones in 1/8" or so. Just make sure what ever size you use is less than the minor diameter of the thread so you don't take out too much.
Old 20th August 2012, 22:22   #8
mattmor
mattmor's Avatar
Thanks. Im going to try this out. BMW shop quoted me 35 hours to remove everything so they could get directly to the threads and remove without damaging anything. Thats a last resort for me. They tried to make it seem like I would be crazy trying to get it out myself as its too easy to damage the engine block. Im not so sure.
Old 20th August 2012, 22:30   #9
fmcfad01
fmcfad01's Avatar
Garage: Anthracite e39 M5; Estoril S54 e36/8
wow, that's laughable.
Maintenance Record
fmcfad01 is offline   Reply With Quote
Old 20th August 2012, 22:30   #10
rao
Garage: Silver 540i
Just take it easy when you are doing this. It is one of those things that is conceptually very easy, but in reality can be quite challenging. Depending on the area around this hole, you should be able to make a repair with a heli-coil if the threads get ruined beyond repair.
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is offline   Reply With Quote
The Following User Says Thank You to rao For This Useful Post:
Some real engine problem advice needed guys. Possible dead engine? jamiepeers E39 M5 and E52 Z8 Discussion 48 26th August 2012 18:30
Pickle Fork or Hinged Ball Joint Separator Norcal M5 E39 M5 and E52 Z8 Discussion 25 4th October 2010 21:38
In a a pickle: Insurance co. vs. Body Shop vs. Me MPire E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 12 16th October 2007 07:24
Please Help! Owning vs. Renting (real estate/financial/property advice) dmcgibbo Off Topic Forum 0 12th April 2005 22:16
