dinan chip -. shark tune - BMW M5 Forum and M6 Forums
Old 19th August 2012, 14:40   #1
firbster
firbster's Avatar
Garage: 2000 m5 carbon black
i just purchased my M5 , i was told that the car has a dinan chip in it , 1 how can i confirm it has the chip(noobie here)/where is it found. and is it actually a chip or a tune. if i remove it does it set the car back to stock??. 2. i would like the shark tune because of the sas fault, can you guys give me some insight here, i have searched but didnt see anything with an answer to this question...thx
firbster is offline   Reply With Quote
Old 19th August 2012, 15:13   #2
sikessr
sikessr's Avatar
Garage: 2001 M5 Jet Black / Black
I'm pretty sure all of the tunes manipulate your software instead of replacing the physical chip. If you remove it, your car won't work.
Edit: Carbon buildup FAQ (summary)
Check out this link. Also check on the Evolve tune. Not sure if it will also remove the fault code, but it can delete the secondary air pump (SAP) feature and is very highly rated on this board.
sikessr is offline   Reply With Quote
Old 19th August 2012, 15:22   #3
jfoj
Garage: 2003 M5 Sterling Gray & 2006 330cic (Vert) Silver Gray
It is not a "chip", it is a flash tune to the DME.
It is hard to tell for sure if the car has something other than a stock tune without software.
You could call Dinan and provide your VIN number and they can tell you if a tune was ever purchased for your car and what level tune was purchased. But they cannot tell you for sure if the tune is currently running in the car.
Unless your car has the over sized throttle bodies, MAF's & headers, your only guessing if the tune is currently running on the car without software to read what is going on. Supposedly if you have the Dinan sized throttle bodies, MAF's & headers the car will not run very well with a stock tune??
You may also want to check out what Evolve offers as well, may be more expensive on the surface than the Shark, but considering you will not have to buy new MAF's, the difference in price may be not an issue in the long run? Evolve offers SAP delete and also can open up the window for post Cat O2 sensor errors along with resolving many performance and driveability issues.
jfoj is online now   Reply With Quote
Old 19th August 2012, 15:52   #4
mfizzlenyc
mfizzlenyc's Avatar
Garage: 2000 m5 silverstone
Easy way to tell... For Dinan software... Where does your idle sit ? On the dot or a bit higher
Reason why a stock car idles right on the dot and a Dinan tune stage 1 and up has a raised idle
2013 Subaru wrx Cobb tuned Daily beater
2009 135 "Worlds First Frozen 1ER" ESS Tuned stage 2
RIP MFIZZLENYCMOBILE - 12/5/2012 2000 Silverstone M5 extended Leather
213,500 miles !!!!!
Evolve Stage 3 Tune
BBS LMs 19s
Michelin Pilot Super Sports ,StopTech BBK,Dinan Headers, CF Plenum cover with clear windows, Dinan CF -CAI,Dinan Air Mass Meters ,Dinan light weight flywheel,Dinan stage 3 suspension ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
mfizzlenyc is offline   Reply With Quote
Old 19th August 2012, 15:54   #5
mfizzlenyc
mfizzlenyc's Avatar
Just saw your located in Europe ??? That brings your chances of having Dinan software way down
Old 19th August 2012, 17:01   #6
jfoj
I think he is in Ontario Canada?
I did hear that Dinan played with their idle a bit, but from my last conversation, they indicated that rather than having 2 idle speeds for standard and light weight flywheels, they went with a single stock idle speed and if you had the light weight flywheel the idle would be about 100 RPM higher?
At least this is what I was told by Dinan, have not seen this in person.
Old 20th August 2012, 20:10   #7
S62E39
Garage: '02 Carbon M5
Dinan should put a sticker on the front side if the driver's door opening. As others said, no way to know whether it was overwritten. Try a Shark tune and if it fails because you don't have stock SW (look up code--lots of posts about this specifically), then you need to have it programmed back to stock before trying the Shark again.
'02 carbon/complete Heritage black, PDC/M-audio/folding seats
Goodies: ST40, ducts, Shark, Dinan susp/camber/braces/exhaust/wheels, UUC SSK
Notable exes: '07 335i modded 6MT sport | '06 MX-5 LSD | '95 M3
S62E39 is online now   Reply With Quote
Old 21st August 2012, 00:53   #8
firbster
firbster's Avatar
i called dinan today and found that my car has the S2 program in it , the rep at dinan asked why i wanted to know if there was a way to remove the tune. i told him the reason (aa code removal) .. then called shark and they told me that the car would have to be flashed back to stock before i could install the shark software, he told me that a 10amp battery charger needs to be put on the car during the software download, the shark tune leave the sas in not ready state. so if thats the case i will just leave the car alone and get a obd2 unit and just erase the code before i need a e-test , same not ready condition!!!...and i can keep the S2 tune..
Old 21st August 2012, 01:35   #9
m5rosemont83
m5rosemont83's Avatar
Garage: 2002 M5 Chiaretto Red
Or you can go with evolve.. Have better software, NO ses light, and have your air pump in a ready state.....
Hard decision I know...
2002 Chiaretto Red purchased with 58k 01/2011
05/10/13@ 102,400 miles
Mods:
Valentine 1 hardwire
Muffler delete
Evolve AlphaN
Predator Ice V5 Halo bulbs
E60 SSK
ILLUMINATED ZHP shift knob
Slimm's CF finned diffuser
Slimm's Euro tilt/slide armrest
Slimm's Alcantara shift boot
Slimm's Alcantara full e-brake
Black Cubic trim
BC Racing BR coilovers
Evolve 4-1 Medusa Headers, cats, X pipe
Evolve Cold air intakes
__________________________________________
My car/vehicle history:
1993 BMW 525i (sold)
1997 CBR1100XX Super Blackbird (sold)
1994 Firebird Formula V8(Total of 3 days )
2002 Jaguar X-type 3.0 Sport manual (sold)
1992 300ZX Twin Turbo (sold)
2002 BMW 530i Sport (sold)
2007 CBR1000RR (RIP)
1988 BMW 325i convertible (sold)
2002 BMW M5
(Current driver)
2002 Chevy Camaro Z28 35th anniversary(sold)
1991 300ZX Twin Turbo super white 130k Miles! (For sale soon! Contact me for details)
m5rosemont83 is offline   Reply With Quote
Old 21st August 2012, 02:13   #10
mfizzlenyc
mfizzlenyc's Avatar
^^^^ very true !!
New to forum, question about removing shark injection tune calc E39 M5 and E52 Z8 Discussion 4 5th August 2012 16:46
550bhp chip tune (UK) god-of-m Off Topic Forum 175 8th December 2010 19:30
Chip ECU tune...HELP! M5knockout E60 M5 and E61 M5 Touring Discussion 5 2nd July 2010 22:43
euro shark injector type chip? aguita E39 M5 and E52 Z8 Discussion 2 26th March 2010 20:24
E39 For Sale: Feeler: Un-used Shark Injector for '00-'03 M5 - TMS Race Tune including headers tune jmlag Parts / Other For Sale or Wanted 0 10th November 2009 04:52
