The quest continues...good example or potential nightmare? - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 12th August 2012, 08:51   #1
OMG
Garage: Old Chebbie
So two months ago I joined the board and began my search for a nice m5 and almost pulled the trigger on one. Like a few of us on this forum it has been a dream car for a long time (although mine is more of a list).
So long story short, I have been saving up more and lurking around on the forum more checking out the DIY's and have found this example on Autotrader.
Again just wanted to get the all-knowing M5B's experience and wisdom's take on it. Does anyone think it is odd that a transmission is replaced at 85k mi? I mean I like that fact but I am concerned because from my experience Manual transmissions do not break very easily. The only thing I can think of is it was tracked.
I emailed the seller with some basic questions. But it's late and I left out a few things that I should have asked also. I also typed a much longer version of this post buy the board login timed out and I lost the post. I will post an update tommorow night.
Look forward and appreciate any and all advice. Thanks again guys and good night.
OMG is offline   Reply With Quote
Old 12th August 2012, 10:09   #2
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
MAJOR SELLING POINT TO THIS CAR: the car has 15K miles on a BRAND NEW FACTORY INSTALLED FLYWHEEL, CLUTCH AND TRANSMISSION.
Well I can't believe it was sent back to Dingolfing, iirc, in Germany to have the Tranny, flywheel and clutch replaced ....
But if it was actually a BMW Main Dealer replacement then, in my mind its nothing to worry about TOO much.
Especially if it was under BMW Warranty and the owner complained of poor shift quality and BMW Warranty had to oblige with a full replacement.
Phone up BMW NA and speak to the Warranty Dept. quoting the VIN and see if this all tallies up.
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 12th August 2012, 13:57   #3
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Replacement tranny is good here.
If a problem develops, Getrag does not make replacment parts available. As a general rule, it cannot be repaired. So the only practical way of repair is a replacment. It comes directly from BMW. While the tranny is out, it makes sense to do a clutch and/or flywheel as appropriate (and I am sure the rear main seal).
The trannys are robust but have a couple of weak points. A few folks have made some repairs, but it usually requires cannibalizing another tranny.
So consider the replacment a plus, as well as relatively rare. Plus, you only have 15k miles on the "lifetime" fluid (change it every 50-60k, 30k if you are anal). Only BMW considers it "lifetime".
Rest of car seems nice, you have the advantage of having access to all the service records, so check them out.
The Following User Says Thank You to gsfent For This Useful Post:
bibledriver (13th August 2012)
Old 12th August 2012, 18:53   #4
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
Tracking is hard on the suspension components, but not on the tranny if heel-toed properly (smooth is fast). Price seems high for 100k though.
Old 12th August 2012, 19:49   #5
ard
Super Moderator
ard's Avatar
Oh, and don't forget...the owner is a service advisor. In all likelihood the tranny was fine and he just wanted a factory fresh one at no cost. Just fudged it about 'notchy shifting' or some such on the warratny form and nobody said boo
I'd be unconcerned about the tranny.
Remember, 1-2k in price should NOT be your sole criteria...
A
Old 13th August 2012, 04:03   #6
OMG
Garage: Old Chebbie
Thanks for the advice guys. I also got an email from the seller and he answered all my questions accordingly. So I will look more into this. Hopefully by the end of the month I will finally own an M5!
Old 13th August 2012, 20:07   #7
OMG
Garage: Old Chebbie
So I talked to the owner today, seem pretty solid. The transmission was replaced under the previous owner under insurance. Funny story I will share later.
In the mean time I'll be meeting him halfway to test drive it in two weeks if somebody doesn't snag it up yet. We'll see how it goes.
Old 13th August 2012, 20:51   #8
gsfent
gsfent's Avatar
Sales Feedback: (3)
Truthfully, I wouldn't wait 2 weeks if you are serious. The car shows nice, bit of a gamble on your part.
Old 13th August 2012, 21:15   #9
dreamerz679
Garage: 03 M5
Before you buy one make sure you go on youtube or the board and search for rod bearings and timing chain guides and vanos noise videos. Make sure you know all the sounds the engine will make normally so that you know what an issue will sound like. I myself have posted a couple videos with my engine noises that were from my timing chain guides failing. Even with these components failing the car will still run and drive, almost as if nothing was wrong. If the transmission has been replaced, is there a warranty on that work? Also run the test on the MAFS. There's a DIY on it. It's quick and easy.
$21k for an 02 with 100k miles? That's very high IMO. I paid $12k for an 03 with 129k with "new" transmission/clutch/flywheel/rotors/pads/mafs/02's/and CPS's. I'm sure someone else has more knowledge on this than me but, is that a "good" price 21k?
dreamerz679 is offline   Reply With Quote
Old 13th August 2012, 21:18   #10
KingJaffeJoffer
Garage: 2002 Jet Black E39 M5
If you're serious, you need to ask if the seller is willing to accept a deposit (a portion of which is non-refundable). Otherwise, I think it unlikely that you'll wind up with this car. Before he drives nearly 5 hours round-trip for you to merely test drive the car, he will sell it locally. That ad is well-written and he comes off as quite knowledgeable. Not gonna last two weeks.
Mods:
Jailbreak Hybrid Alpha-N tune
Muffler delete with timmay tips
BeastPower RSB brackets
KingJaffeJoffer is offline   Reply With Quote
The Quest for Perfection Steve Mac E34 M5 Discussion 23 19th February 2011 01:18
The Quest for 140 SLC00M5 E39 M5 and E52 Z8 Discussion 51 5th May 2010 12:25
A Man and his M5 Quest SehrSchnell E39 M5 and E52 Z8 Discussion 14 22nd December 2006 01:46
My new car quest (Z4 M Coupe!) palantirion E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 113 13th November 2006 12:58
Osh's nightmare continues... Black M5 E39 M5 and E52 Z8 Discussion 30 5th July 2004 20:40
