Noob question regarding Konis - BMW M5 Forum and M6 Forums
Old 11th August 2012, 08:23   #1
olegd88
olegd88's Avatar
Garage: 2001 BMW M5 - Carbon Black
Hey guys,
So I was finally about to get my rear koni yellows and dinan springs installed, however neither I nor the mechanic could figure out how to properly adjust the rear shocks. Ive read that they must be 1.25 turns from full soft, however I am not sure what "full soft" is.
How do you guys adjust them properly? I tried locking them into a vise (being careful not to damage the thread), then compressing them by hand and trying to turn them. I feel something on the bottom, and I think the firmness is changing, however I am not sure at which end (soft or firm) it is.
From my understanding, I have to pay turn it all the way to soft, until it cannot be turned anymore and then turn it 1.25 turns.
Any input is really appreciated.
Thanks in advance.
olegd88 is offline   Reply With Quote
Old 12th August 2012, 04:01   #2
olegd88
olegd88's Avatar
Anyone??
Old 12th August 2012, 04:41   #3
josiahg52
josiahg52's Avatar
Garage: 2001 Jet Black/All Exclusive Black/Black Cubic M5, Supercharged 2001 Tahoe LT 4x4
Sales Feedback: (6)
The problem with going from the SOFT adjustment is that you don't know how many turns "out" full SOFT actually is and then if you go adjusting from that point the shocks may not be at equal adjustment points. It may not be enough to matter, but I went from full HARD.
To adjust from full HARD:
- Depress the shaft all of the way in.
- While holding the shaft in, turn it clockwise until you feel the stop; continue holding the shaft in.
- Turn back the shaft the desired number of turns.
To adjust from full SOFT:
- While holding the shaft in, turn it COUNTER-clockwise until you feel the stop; continue holding the shaft in.
- Release the shaft.
Again, I don't recommend adjustment from full SOFT.
-Josiah
2001 ///M5 Jet Black/All Exclusive Black/Black Cubic - 3/2001 production "UNTIER"
josiahg52 is online now   Reply With Quote
Old 12th August 2012, 04:42   #4
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
It's been too many years since I've adjusted the rears, but see this link from Koni to see if it helps. Yes, Dinan recommends 1.25 turns off full soft, so that part is correct. I think for the Dinan springs and valving it is about perfect. It won't feel underdamped, especially at slow speeds. Dinan spring rates are well under the GC rates.
Current stable:
Dinan: springs, Konis, rear sway bar, monoball bushings, and exhaust;
Ground Control camber plates, Stoptech front BBK, Brake ducts opened,
Evolve AlphaN tune,
OE 9.5" rear wheels all around & 275/35-18 Pilot Super Sport
2011 M3 sedan 6MT Silverstone, no sunroof!
1996 Volvo 850R wagon
herd has been thinned, looking for some new acquisitions...non-sunroof E90 M3 = found
CSBM5 is offline   Reply With Quote
Old 12th August 2012, 04:45   #5
josiahg52
josiahg52's Avatar
Sales Feedback: (6)
Good point: it does depend on the type of spring and the spring rate that the OP is using. I didn't think of that.
Old 12th August 2012, 23:58   #6
olegd88
olegd88's Avatar
Thanks for the input guys. I did try the above earlier, however for some reason I could not find the stop for full soft. I think I found the spot for full hard, because at that setting the shock just wouldnt open back up for a while.
Also, when you say clockwise, counterclockwise, which way are you looking at the shock.. is it right side up (the way it is mounted in the car), or upside down, the way most people adjust them in a vise?
Am I correct to assume that there will be a stop at the Full soft point as well as the full hard point? Perhaps I am not pressing it down all the way, since it is pretty hard to keep it down while turning.
Seems like something so simple, but yet very frustrating for me right now.
Old 13th August 2012, 00:43   #7
CSBM5
CSBM5's Avatar
From what I recall (and this is a bit foggy), it is as-installed looking down from above -- use that orientation for clockwise/counterclockwise. Clockwise = firmer, counter = softer. Yes, there are hard stops at full hard and full soft, and they should be about 2.5 turns apart from each other. You will have to ensure that once you engage the adjuster that you keep downward pressure on the shaft while turning to your desired adjustment. Hopefully you can verify the direction vs rebound stiffness by sampling it at full soft vs full hard locations by hand.
Old 13th August 2012, 01:54   #8
josiahg52
josiahg52's Avatar
Sales Feedback: (6)
Adjust the shock as looking down on the shock as installed on the vehicle. The soft "stop" is very, well, soft. You can easily blow right by it. IIRC, it is just distorted threads. My left shock was a little over three turns from hard to soft and the right was a little over 3.25 turns which is why I did not adjust from the full soft adjustment.
Old 13th August 2012, 03:44   #9
olegd88
olegd88's Avatar
I am sure I will realize how simple it all is once I figure it out, however.. that just confused me more.
What do you mean that I can blow past it? Is it not a defined stop where it can no longer turn anymore?
Old 13th August 2012, 07:28   #10
josiahg52
josiahg52's Avatar
Sales Feedback: (6)
Yes, if you apply to much torque you can go past the full-soft stop. It is not a solid stop like the full-hard stop is.
Sent from my Samsung Galaxy S™ II, Epic™ 4G Touch (Sprint) using Tapatalk 2
Another noob question, sorry, but if can explain, i'd appreciate it!! Ti-Cip E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 32 30th January 2012 16:38
Noob question (oil)... Nosurrender E60 M5 and E61 M5 Touring Discussion 20 14th May 2011 01:35
Noob Question SL333PR E39 M5 and E52 Z8 Discussion 4 15th May 2010 18:47
Noob AA CAI question. rost12 E39 M5 and E52 Z8 Discussion 2 16th May 2005 01:55
Question for Luke@Tirerack regarding Konis jmott Off Topic Forum 2 14th February 2003 22:29
