New chain tensionor won't thread in.. - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 11th August 2012, 04:30   #1
CarbonHan
CarbonHan's Avatar
Garage: 2002 Carbon Black M5
After reading vantaam5's DIY post: Chain tensioner change DIY with pics ..
...I thought the job looked fairly easy and straight forward so I ordered the chain tensionor and crush washers to do this after work. I got the old one off pretty easily. But when it came to putting in the old one.. i can't get it to start threading in! I'm pushing with all i have while turning the ratchet clockwise but its won't grab. I've been at this for the past 1 and a half hour with no success. I've officially given up for the night because i honestly feel like im going to break my left hand from pushing the ratchet in.
PLEASE somebody enlighten me on how to get this damn thing on.
The Beast - 2002 Carbon Black M5
///Stock
CarbonHan is offline   Reply With Quote
Old 11th August 2012, 06:26   #2
Nabio
Nabio's Avatar
Garage: Jet Black E39 M5
It may be easier just to use your hand to get it threaded and turn it initially, I feel like that's what I ended up doing when I changed mine.
Jet Black 2000 M5
Nabio is offline   Reply With Quote
Old 11th August 2012, 09:46   #3
CarbonHan
CarbonHan's Avatar
i tried to thread it in by hand but i don't have enough strenght to push with my finger..
Old 11th August 2012, 12:31   #4
jamiepeers
jamiepeers's Avatar
Garage: E39 M5 Carbon Black
Silly question.
Can you thread the old one in easy enough?
If so, likely the issue is with a small burr or such on the new tensioner. Inspect the tensioner at the very tip of the thread and see if its formed ok or not. Could be you just need to dress the start point with a fine file etc.
jamiepeers is offline   Reply With Quote
Old 11th August 2012, 13:59   #5
cumbrian
Garage: 2003 E39 M5 Jet Black
Originally Posted by jamiepeers View Post
Silly question.
Very sensible question!! So easy to overlook the blindingly obvious when you're at the "I'm never going to do another **&!!@@£ job on this !**$£@!! car again!" stage.
cumbrian is offline   Reply With Quote
Old 11th August 2012, 19:58   #6
CarbonHan
CarbonHan's Avatar
Silly question.
I tried using the old head of the screw to see if i could thread that in. No luck whatsoever.
Do you think i need a thinner 19mm socket? I'm thinking maybe im not getting enough clearance..
Old 11th August 2012, 20:22   #7
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
Try just take the bolt (without the spring, etc.) and screw it in by hand, if it goes on, then it simply implies you're not putting enough pressure to overcome the spring. If it doesn't (and this is where you want to test fit the old one to make sure you haven't cross threaded the hole), it will indicate the new bolt thread needs to be burred. I think that's what Jamie is referring to above.
The Following User Says Thank You to bimmerule For This Useful Post:
jamiepeers (11th August 2012)
Old 12th August 2012, 12:36   #8
Essixtytwo
Essixtytwo's Avatar
Garage: 1998 E39 M5 Carbonblack
Difficult or not, it can be done using your hand, and you should. You have no feeling of what you are doing using your rachet to push and turn, there's a big risk of stripping the threads and if you do, you really got a problem.
Eat some spinach and push/turn it in by hand.
Le Garage:
1998 E39 M5 (yes, that's right, going EXTREMELY strong and ZERO oil/rattle issues), Carbon Black/Caramel Full/Alcantara.
1985 E28 525i, Alpine White/Pacific, 12 yrs of ownership, DD during winter, most reliable car ever.
Essixtytwo is online now   Reply With Quote
Old 12th August 2012, 12:45   #9
Essixtytwo
Essixtytwo's Avatar
It's best if he uses the bolt of the old tensioner to test fit and clean up any burss if present. Like Vantaam5 later wrote in his DIY, the new tensioner should not be disassembled because of the small lock inside (keeping the parts together for easy installation). If you take it apart it becomes decompressed making it much harder to install.
The Following User Says Thank You to Essixtytwo For This Useful Post:
Sailor24 (14th August 2012)
Old 12th August 2012, 14:01   #10
ger
ger's Avatar
Garage: M5 Le Mans Blue
That's what I'm thinking, that it's extended a bit making it very hard to install.
Compare its length to the old one, it should be shorter.
Iirc it uses oil pressure to extend outward to a certain tension (hence the clatter when you first stat the engine), then the spring takes up the little variances as the engine runs.
I can't remember how easy it is to compress it all again, not that difficult I don't think.
11/2000 M5 Le Mans Blue
My car's thread
ger is offline   Reply With Quote
HELP! QUICKLY! Chain Tensioner won't go back in! jrhaile E39 M5 and E52 Z8 Discussion 9 23rd August 2009 01:10
Rear Doors won't Lock / Trunk Won't Open undfined E39 M5 and E52 Z8 Discussion 16 18th April 2009 22:38
Chain Tensioner SteveT E34 M5 Discussion 13 20th November 2006 04:01
Timing Chain Tensioner Thread That WILL be deleted!! IvanDias E34 M5 Discussion 12 10th April 2006 03:02
chain tensioner? Sebring NL E34 M5 Discussion 15 11th December 2005 20:01
