Help identifying headlight "trim seal" part - BMW M5 Forum and M6 Forums
Old 10th August 2012, 23:05   #1
S62E39
Garage: '02 Carbon M5
I hope you guys can help me figure out a confusing part situation:
I mistakenly thought P/N 51138168812 was the rubber trim piece at the top of each headlight. That's #8 in the diagram with the grille.
However, it's definitely not--those are P/N 63126908405 and 63126908406 (#1 in the headlight close-up diagram).
Does anyone know what the first seal does, and where it's used? I can't see where to replace it. Has anyone replaced one and could give me a tip?
Thanks!
'02 carbon/complete Heritage black, PDC/M-audio/folding seats
Goodies: ST40, ducts, Shark, Dinan susp/camber/braces/exhaust/wheels, UUC SSK
Notable exes: '07 335i modded 6MT sport | '06 MX-5 LSD | '95 M3
S62E39 is online now   Reply With Quote
Old 10th August 2012, 23:44   #2
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
You mean you bought something you don't need? Welcome to the club.
Old 10th August 2012, 23:49   #3
S62E39
Ummm...no...never bought anything I didn't need or that didn't fit (nose is growing...)
Luckily the little rubber strips were the cheapest dealer item I've ever seen--$2 each. The more substantial, correct piece is $20 from the dealer.
I'm heading to pick it up soon--dealer's my only option since I'm heading out on my cross-country drive on Monday. Don't want worn front end seals when I'm driving 3,200 miles through some pretty strange weather in the middle of the country!
Old 10th August 2012, 23:53   #4
bimmerule
bimmerule's Avatar
Sales Feedback: (8)
[quote=M5hunting;2373354]Ummm...no...never bought anything I didn't need or that didn't fit
quote]
You have much to learn. Have fun on the trip, they don't the M5 autobahn monster for nothing.
Old 11th August 2012, 06:42   #5
bibledriver
bibledriver's Avatar
Garage: 02 M5 Le Mans Blue
The seal you bought goes between the painted trim piece (below the Headlight) and the headlight itself. What it does, well, suppose it helps stop stuff and moisture from taking that route. Air inlet snorkel is not far away. . . anyhow, that is where it goes!
bibledriver is offline   Reply With Quote
K&N intake SEAL + "Increased emissions" light fix Nickmola E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 7th August 2011 13:08
E39 Want to buy: 2001-onwards "angel eye" Headlight Lenses (UK) pete_griff Parts / Other For Sale or Wanted 2 5th January 2011 09:46
Rear Main Seal leak?? - Need help identifying DMJ///M E39 M5 and E52 Z8 Discussion 15 22nd January 2009 03:39
Update: "Front Suspension" noise is actually a door seal! spinexoxo E39 M5 and E52 Z8 Discussion 8 10th June 2007 16:49
UPDATE: Dinan is coming out with a "add on" part for their CAI system........... FAST 5 E39 M5 and E52 Z8 Discussion 9 4th March 2003 02:57
