Put this to bed plz! - BMW M5 Forum and M6 Forums
Like Tree14Likes
Old 7th August 2012, 13:09   #1
Topaz540i
Topaz540i's Avatar
Garage: 01 540i/6 sport Topaz Blue
Someone claims to have a dyno graph showing a nonvanos 540 makes equal power up to 5k rpm asthe m5.
Plz jump in and point out whats true and what isnt here.
Interesting M62/S62 dyno over-lay - Bimmerforums - The Ultimate BMW Forum
Topaz540i is offline   Reply With Quote
Old 7th August 2012, 13:16   #2
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
it's an anemic M5 if it is one, at all. where's the torque graph?
314whp compared to 261hp (@ their peaks) doesn't quite add up.
mattmartindrift is online now   Reply With Quote
Old 7th August 2012, 13:34   #3
Clemster
Garage: 2010 E90 M3 Alpine White/Fox Red
Sales Feedback: (26)
This^^^
BF.com ftw....again.
Former Owner of this Beast!
2003 M5 Silver on Black/Silverstone Sport
ESS S/C w/ 92mm pulley
Methanol Injection via Howerton Engineering and Aquamist HFS-3
Brembo 355 Front/345 Rear/Drilled Rotors
3.45 Dinan Differential
Brecus Stage 4 Feramic Clutch
Ground Control Coilovers
Fikse Profil 5s/PS2's
Dinan RSB w/ Beastpower Brackets
Muffler Delete with TimmayTips
UUC SSK w/ DSSR and ZHP Shift Knob
0-1320' in 11.72 @ 121.04
Clemster is online now   Reply With Quote
Old 7th August 2012, 13:37   #4
Topaz540i
Topaz540i's Avatar
Lol yea but i wanted u guys to post over at bf.com so they can hear the truth themselves from m5 owners. The m5 section at bf is dead.
Old 7th August 2012, 15:41   #5
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Elegant Solution : Search M5 vs 540i on Youtube !
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 7th August 2012, 16:42   #6
JoeFromPA
Garage: 2001 Carbon Black/Caramel M5
Sales Feedback: (3)
The dyno is about how they perform up to 5k rpms and the truth is not too far off from that post - the 540i and the m5, on a dyno, look very very similar up to 5000 rpms. That is why a 540i with an m5-equivalent rear diff gearing feels almost identical from a butt dyno perspective.
I don't know why this is a surprise to anyone...despite having an extra half liter of displacement, the s62 is setup to be a bit more of a high horsepower screamer. The ITBs and alot of the other differences between the m62 and s62 are about responsiveness and agility of the engine, but that doesn't show up on a dyno.
There is a fine case to be made about why some people should own a 540i instead of an m5, depending on their needs. I fit the bill, given the amount of driving I do. However, I wanted everything the m5 had to offer in addition to the engine.
So I say, no, ,this isn't put to bed, it's pretty close to reality. Don't forget too that the 540i has a modest, but meaningful, weight advantage as well.
2001 Carbon Black on Caramel - 121k miles (4/2/2013)
JoeFromPA is offline   Reply With Quote
Old 7th August 2012, 17:09   #7
Topaz540i
Topaz540i's Avatar
Thats only fair if the 540 has an m5 3.15 lsd. Stock is open 2.81
Old 7th August 2012, 18:01   #8
JoeFromPA
Sales Feedback: (3)
Incorrect. It would only be fair if the m5 and 540i shifted at m5.
The point is not comparing acceleration times of the two cars/engines - it's well known the m5 is faster due to it's top-end.
The point is a comparison of the output of the two engines up to 5k rpms.
And to that end, the BF thread is close to correct.
Old 7th August 2012, 18:13   #9
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Agree, that is the by far the healthiest 540 and the unhealthiest M5 engine outputs I have ever seen.
Stock 540 is 282. So using the 15% drivetrain loss as we use for the M5, that puts PEAK rwhp at about 240, vs most M5's about 325-330. So the 540 is overstated by 20 rwhp and the M5 is understated by 20 rwhp at maximum. A 40 rwhp difference.
I recognize the shape of the hp curve may be different and the 540 runs closer to the M5 below about 4500- 5000 rpm, but the numbers are still a bit off.
Old 7th August 2012, 18:31   #10
Topaz540i
Topaz540i's Avatar
Depending on year 540 is rated as much as 298hp even though all vanos are identical. Maybe it was a software update? The 540 factory press numbers are generally considered low because they typically run 260 at the wheels in stock form.
For the youtube comparison comment, i figured he meant find a youtube of them drag racing which is far more likely to be posted than dyno runs.
Put the Beast to Bed for the Winter Dmax27 E60 M5 and E61 M5 Touring Discussion 27 17th October 2009 18:03
Wanna put 305/25/20 on rear what should I put on front? jfisher08 E60 M5 and E61 M5 Touring Discussion 10 27th June 2009 20:13
Put in New MAF , need to put back stock filter rstringer E39 M5 and E52 Z8 Discussion 10 11th June 2009 07:49
How to flat bed your M5 ?? M5Rick E39 M5 and E52 Z8 Discussion 7 7th April 2003 21:50
Funny , celica baord talking about M5 Vs Z06,,put comments plz Germancars Off Topic Forum 0 20th January 2003 07:15
