8th August 2012, 00:44
#6
2002 Sterling Gray
Hi-
Welcome to the M5 board. You should post some pictures of your car and introduce yourself if you haven't already.
You probably got off on a rough start with the random aftermarket radio link--sorry!
As long as you have MKIV, you can add a sirius module-there was a thread on this not to long ago--something along the lines of "sirius modules now available" with a link to part numbers.
You can also add a aux input for Ipod to the MKIV.
Adding bluetooth is more involved, but again there is great resources on here that lead you through using a ULF or TCU, along with a BT antenna, etc. I believe build dates after 9/2 have most of the guts in them already to make it easier.
Or, you can always just go the DICE Mediabridge route and get an all-in one. It is "close" to OEM and uses the CD changer input as a work around, so it takes a bit to get used to.
Good luck!
