Weird "Supercharger" sound in 1st, 2nd and 3rd gear? Videos attached - BMW M5 Forum and M6 Forums
Like Tree9Likes
Old 5th August 2012, 05:01   #1
dimi_108
dimi_108's Avatar
Garage: 2003 E46 M3 Le Mans Blue
I have a bone stock 2000 E39 M5.
I've noticed a whining sound in 1st, 2nd and 3rd gear which can be heard outside.
I have no modifications.
  • I've recently changed the gearbox oil to Royal Purple Synchromax
  • I've recently changed my rear diff oil using OEM BMW fluid with +FM
  • I have recently had my clutch changed 1000 miles ago...
I don't mind the sound at all. My only concern is something is going to blow up and leave my passengers stranded.
Any suggestions would be great.
Video on post #17
Current ///M
2003 Le Mans Blue M3 SMG Individual
Previous ///M's
2000 Carbon Black M5
2002 Carbon Black M3 SMG
dimi_108 is offline   Reply With Quote
Old 5th August 2012, 05:43   #2
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
Search using keywords: "fan clutch", "newspaper"
If you pass that test, and it only happens under hot ambient conditions, then file it under normal behavior.
chowdah is offline   Reply With Quote
The Following User Says Thank You to chowdah For This Useful Post:
dimi_108 (5th August 2012)
Old 5th August 2012, 06:33   #3
dimi_108
dimi_108's Avatar
Okay so i gave the fan a wiggle and it seemed to be fine.
As for the rolled newspaper trick, i'm not sure if i did it right but this is what i did anyway.
Does it look okay to you?
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Old 5th August 2012, 06:39   #4
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
How did you start the car without depressing the clutch?
bimmerule is offline   Reply With Quote
Old 5th August 2012, 06:44   #5
desmotesta
desmotesta's Avatar
Garage: 2002 M5 TiAg
Exactly! How did you do that?
And doesnt the car have to be COLD for your to do the fan clutch test? your Oil temp was pretty warm wasn't it?
02 TiAG M5 - 74K Mls, Matt's latest Alpha-N, Muffler delete, E60 SSK, UUC DSSR, Dinan Strut braces, Dinan Sway Bar
02 Audi A6 Quattro
04 Aprilia RS250 (Race)
90 Honda CB-1 (Wife's race bike)
2004 Yamaha PW50 (son's)
desmotesta is offline   Reply With Quote
Old 5th August 2012, 06:45   #6
dimi_108
dimi_108's Avatar
What? I read on the threads that the car has to be at operating temperature?
Old 5th August 2012, 06:54   #7
mgdmb
mgdmb's Avatar
Garage: '00 M5 CB Faux S2
Sales Feedback: (3)
Pretty sure only US spec cars have the clutch safety switch... and that can be disabled with P.A.Soft:
Coding out Clutch Depression Switch Start requirement
mgdmb is offline   Reply With Quote
Old 5th August 2012, 06:58   #8
dimi_108
dimi_108's Avatar
So does it look okay to you?
Old 5th August 2012, 07:09   #9
bibledriver
bibledriver's Avatar
Garage: 02 M5 Le Mans Blue
Man, I was expecting to hear an RK supercharger blast you to the moon! lol
I coded out my safety switch on accident, and it caught me off guard one day! Startled the piss out of me!
The way I understand it, the clutch fan will have more friction when it is cold, so until it runs a bit, it will be more connected to the pulley. Once the fluids in there warm a bit, then it will be much less connected and freewheel on the pulley until it is hot enough to begin engaging more and more, to finally cool down by the amount of air coming through and cooling it and the water in the radiator core.
Dimi, if you hear the whine all the time (but in 4,5, and 6 there is more and more road noise) then it could be locked up. One of the problems people have seen. This means, you would hear it sitting in your driveway.
If you had to say "it is coming from ______," what area of the car would you fill in the blank with?
Is it coming from the engine bay? below you? Does the pitch of the whine change with the engine speed, or does it change with road speed??
bibledriver is offline   Reply With Quote
The Following User Says Thank You to bibledriver For This Useful Post:
Old 5th August 2012, 07:15   #10
dimi_108
dimi_108's Avatar
Thanks mate. It's dfinitely coming form the engine. It sounds like a "turbocharger on a cold morning". So it doesn't have the "sssssssssSSS" whistle noise, it's more a low pitched sound like a siren.
The pitch will "heighten" as the RPM's increase. And it can be heard from outside.
Basically if you try to mimic a siren by blowing out with your lips. Like a woooooOooooo sound
clutch "bouncy" in 2nd gear. jeffseal E39 M5 and E52 Z8 Discussion 8 27th March 2011 05:09
Engine sounds "heavy" at 2nd gear 3000 RPM cpark352 E39 M5 and E52 Z8 Discussion 5 9th December 2008 17:39
Can M5 "Chirp" 1st, 2nd, 3rd gears? WIRELESS E39 M5 and E52 Z8 Discussion 20 18th January 2003 12:01
Proper 1st Gear Launch ("racing") ALittleLuck E39 M5 and E52 Z8 Discussion 23 8th February 2002 05:19
M5 Depreciation Rates 1st,2nd, and 3rd year ALittleLuck E39 M5 and E52 Z8 Discussion 1 15th September 2001 23:43
