Can M5 use 530i trunk floor? - BMW M5 Forum and M6 Forums
Old 4th August 2012, 11:41   #1
S62E39
Garage: '02 Carbon M5
Title pretty much says it all: Can I buy an E39 530i trunk floor (the gray folding piece with foam underneath) and use it in my E39 M5?
If so, is it simply a matter of pulling the old one out and placing the new one? Is it secured at all? I haven't been able to figure it out looking at mine.
Reason I'm asking: My current folding floor is separating from the foam underneath, and I have a bead on a decent 530i trunk floor.
Thanks!
'02 carbon/complete Heritage black, PDC/M-audio/folding seats
Goodies: ST40, ducts, Shark, Dinan susp/camber/braces/exhaust/wheels, UUC SSK
Notable exes: '07 335i modded 6MT sport | '06 MX-5 LSD | '95 M3
S62E39 is offline   Reply With Quote
Old 5th August 2012, 06:02   #2
S62E39
Crickets...
I've decided that since the part appears to be $300+, I'm going to use spray adhesive to reacquaint the top layer with the foam layer.
[/thread]
Old 6th August 2012, 03:45   #3
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Originally Posted by M5hunting View Post
Crickets...
[/thread]
You stumped the board. You get a
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline   Reply With Quote
Old 6th August 2012, 04:12   #4
JohnAnthony
JohnAnthony's Avatar
Garage: Silverstone
in overall shape yes
but according to this diagram... no
the 530i looks like it has a larger piece since it carried a spare tire, while the M5 has smaller pieces since it has the battery underneath
530i
RealOEM.com * BMW E39 530i Trunk trim panel
item #1
M5
RealOEM.com * BMW E39 M5 Trunk trim panel
item #15
bmw is not that dumb, if they have a part that is used across many models they will charge you the same price
i.e.
item #15 for the 530i/item #13 for the M5:
51478159480
can always try trimming the floor off the 530i
JohnAnthony is online now   Reply With Quote
Old 6th August 2012, 04:32   #5
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
It doesn't fit. I just checked.
Old 6th August 2012, 05:53   #6
S62E39
Thanks, all!
Old 6th August 2012, 07:10   #7
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
AFAIK they are the same.
E55AMG2 is offline   Reply With Quote
E39 For Sale: FS E39 Trunk Floor Mat Carpet drewdwn Parts / Other For Sale or Wanted 7 1st December 2010 08:03
E39 stuff. Carpet floor mats, winter floor mats, carpet trunk mat someday Parts / Other For Sale or Wanted 18 28th February 2010 19:15
M5 embroidered floor mats and trunk liner Carl Lassiter E60 M5 and E61 M5 Touring Discussion 46 20th January 2009 20:53
E39 trunk floor needed! holmesmd E39 M5 and E52 Z8 Discussion 1 25th May 2008 02:01
Mats – Floor and Trunk Terk E39 M5 and E52 Z8 Discussion 16 6th February 2003 18:22
