fault codes after diagnose. - Page 2 - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 7th August 2012, 03:46   #11
68FB
Garage: 2001 M5 Ti Silver
Now that's a valuable engine!
After 9 years in storage, the pintles (pistons) may be stuck in the VANOS solenoid valves. The clearances are pretty tight and any varnish build-up would lock them up. Same goes for the solenoid valve on the accumulator, although I think the DME only monitors for electrical problems with the solenoid coil on that, and would not detect sticking.
Might be worth pulling the boards and doing the VANOS cleaning and listening for them clicking. But first you need to check you are actually getting a signal to them from the DME. Pins 1, 3, 4, and 6 on the connectors near the VANOS units energize the coils. Check for volgtage at any of these pins. Use the AC volts and DC volts selector on the multimeter.
Name:  Board wiring diagram.JPG
I'm still curious about how the tuner is controlling the VANOS. Is he using a M5 DME? From what I have read it is very difficult to program an aftermarket ECU to control the S62 VANOS.
Of course, if you can only run the engine for 25 secs, this troubleshooting is tough to do.
68FB is offline   Reply With Quote
Old 7th August 2012, 04:43   #12
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
You have a code for every solenoid like it is being starved for oil or they are all plugged, don't think that is possible. Logical thing is they are not getting a good oil supply.
68FB Where does the oil pick up for both of the high pressure pumps?
Still have not found anything credible to know exactly what 172 is, sorry. Read lots of speculation but nothing solid.
Sailor24 is offline   Reply With Quote
Old 7th August 2012, 06:29   #13
68FB
The oil supply to the pumps come off each cylinder head through the upper chain tensioner and into the 0.5 bar pressure regulator below
and feeds into the VANOS units here. You can see the feed hole to the pump in the right hand unit.
There is a filter mesh in the regulator but it's getting filtered oil so shouldn't be plugged.
Old 7th August 2012, 14:14   #14
Sailor24
Sailor24's Avatar
Thanks , also not likely that both would fail at the same time. Could be the other way and too much pressure, if the return was plugged. I would think that oil might show up in the intakes if that were true, but The returns are separate also are they not? That leaves the code 172 for the accumulator. It appears to be an electric valve issue. If the valve was stuck and effectively eliminating the accumulator what would happen? I think it might make the pressures spike in both direction, this might be enough to cause the cams to be in there wrong location?
Old 7th August 2012, 17:28   #15
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Originally Posted by ///M5 Touring View Post
the engine is a 2001
Here lies the main issue !
Good Luck !
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 8th August 2012, 18:49   #16
///M5 Touring
Garage: S62B50 powered E34
i will check if there is a signal to the boards and cam sensors.
where is the vanos pressure pump located at? is it electric powered/signal controlled?
and to remove det boards, just to unscrew the bolts and take off the cover? nothing else i should be careful of when removing them?
///M5 Touring is offline   Reply With Quote
Old 8th August 2012, 18:51   #17
///M5 Touring
Good Luck !
really huh, care to explain
Old 8th August 2012, 19:55   #18
M5 London
M5 London's Avatar
You wouldn't have this problem with a 99.
The 99 DMEs were all built in Germany and from about 1st April 2000, roughly exactly, all the DMEs were built somewhere else and very cheaply too !!
Which generally lead to several problems on the already under performing 'Wrong Piston Ring' cars.
Jeg fleiper bare.
Old 9th August 2012, 05:02   #19
///M5 Touring
anyhow, thanks to the serious people on this forum for help
have checked the wires from ecu to the camshaft sensors, and everything is ok there.
checked the wires from ecu to the contact for the solenoid boards, everything ok there aswell.
and took out the solenoid boards to check if they clicked, and they do. but how much should they open? if i look in the little hole in front of the solenoid it is just barely retracting in to the solenoid.
i have filled new oil in the engine before starting it, but it seems like old oil that came out when i removed the boards. shouldnt it be a hint of new oil if they are working correctly?
i have this vanos pressure accumulator. how does this work exactly? is it possible this is stuck somehow?
here is picture of the boards if you can see something wrong maybe.
Old 9th August 2012, 06:07   #20
Sailor24
Sailor24's Avatar
Is there an electric plug in on your accumulator? That appears to be a pre vanos upgrade accumulator and should not have the 172 code. This makes me think your tuner may have not understood the engine you have.
The dirty oil in the nodes suggests that new oil is not being supplied to them. Your codes suggest the same thing. I have no clue what could do that. Have you checked to see if you have oil pressure in the engine?
If the number was
11367832189
then it might get a 172 code. I believe your engine is a pre 12/2000 engine, I suspect the DME you were supplied with is for a 1/2001 engine.
Diagnose my beasts spark plugs! With fault codes Bisan E39 M5 and E52 Z8 Discussion 13 28th December 2011 03:00
Please help diagnose fault codes sshu930 E39 M5 and E52 Z8 Discussion 15 18th July 2011 22:21
I have these five fault codes on my M5 fresh E60 M5 and E61 M5 Touring Discussion 3 23rd March 2010 04:28
Help with fault codes? Vason E39 M5 and E52 Z8 Discussion 6 25th August 2006 13:57
need help with fault codes please jkarp E39 M5 and E52 Z8 Discussion 1 7th January 2005 05:30
