OE code and fuel smell in car - BMW M5 Forum and M6 Forums
Like Tree2Likes
  • 2 Post By 68FB
Old 25th July 2012, 23:00   #1
desmotesta
desmotesta's Avatar
Garage: 2002 M5 TiAg
As the title states, In the last two months I have received the "OE" code twice and I have also smelled gas fumes, 2-3 times, in the car when the car was running. On both occasions (when I smelt gas) car was running and the smell was coming from the air condition vents.
Does anyone have any idea on where I should start looking for a leak if the smell is coming from the air condition vents?
On of my air tubes (that connect the cabin filter to dash) doesnt allign 100% so its safe to say that the smell is from under the hood.
Where should I look for a leak under the hood? As the gas fume symtom has only happened twice, its not present all the time and otherwise there is NO gas smell what so ever.
Thank you for your insight
02 TiAG M5 - 74K Mls, Matt's latest Alpha-N, Muffler delete, E60 SSK, UUC DSSR, Dinan Strut braces, Dinan Sway Bar
02 Audi A6 Quattro
04 Aprilia RS250 (Race)
90 Honda CB-1 (Wife's race bike)
2004 Yamaha PW50 (son's)
desmotesta is offline   Reply With Quote
Old 26th July 2012, 03:01   #2
bdsmitty88
bdsmitty88's Avatar
Garage: 2000 BMW M5 Carbon Black Metallic / Black Full Leather
Sales Feedback: (3)
Des,
The connectors tubes for my cabin air filters on my car do not connect flush by any means. 2 of the 3 hooks are broke on each, so the fitment is less than snug. I never got smells in through the cabin tubes though, even when I had a large oil leak.
Are you certain that it is coming from the engine and not anywhere else?
2000 BMW m5 Carbon Black Metallic / Full Black Leather / Aluminum Trim
Matte Black Kidneys - Monochrome Trunk/Hood Roundels - Monochrome Trunk Badge - Slimms Finned Rear Diffuser: Matte Black
545 SSK - IATS Relocation
Full Interior / license plate LEDs
BBS RS-GT Diamond Black / Polished Lip
Muffler Delete
Evolve Alpha-N tune
60K Miles 8/15/12
bdsmitty88 is offline   Reply With Quote
Old 26th July 2012, 03:14   #3
desmotesta
desmotesta's Avatar
Originally Posted by bdsmitty88 View Post
Des,
At the time (twice) it really did seem like the smell was coming from the air vents, but I had been running the AC for 25-30 minutes and who knows if the smell was just circulating from the back to the front.
I have tried searching the board and have even googled for "0E" but not much information comes back. I know it means "small tank leak" but I cant find many reports/posts of other people experiencing the same thing.
Old 26th July 2012, 03:56   #4
68FB
Garage: 2001 M5 Ti Silver
The M5 has a fancy system for detecting leaks in fuel tank and associated venting system. This is from the M5 training manual:
Functional Overview:
The DM-TL is located in the drivers side rear wheel well in the M5.
1. In it’s inactive state, filtered fresh air enters the evaporative system through the sprung
open valve of the DM-TL.
2. When the DME activates the DM-TL for leak testing, it first activates only the pump
motor. This pumps air through a restricted orifice (1.0 or 0.5 mm) which causes the
electric motor to draw a specific amperage value. This value is equivalent to the size of
the restricted.
3. The solenoid valve is then energized which seals the evap system and directs the pump
output to pressurize the evap system.
The evap system is detected as having a large leak if the amperage value is not realized, a
small leak if the same reference amperage is realized or no leak if the amperage value is
higher than the reference amperage.
Maybe you are smelling gas when the DM-TL pump is pressurizing the tank and EVAP system to do the test. There may be spots that are common leakers on the M5 and others can advise but I noticed today when I was under the car that the vent tubing from the tank to the EVAP valve on the engine was pretty corroded.
The training manual (which has been known to be wrong) also says this test is done with the engine off.
68FB is offline   Reply With Quote
Old 26th July 2012, 04:13   #5
desmotesta
desmotesta's Avatar
the restricted.
Thank you for the information, did not know any of what you posted.
I am and will continue to look for posts and information regarding "small tank leak" and hope someone else out there has dealt with this and can elaborate on how to confirm that its a real issue, and how to resolve it.
Old 26th July 2012, 16:44   #6
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
This code is also most commonly called the gas cap code. First clear the code put some dielectric grease on the gas cap seal and make sure it is tight every fill up. See if the code comes back. You are connecting the two items but they could be separate. If you had a fuel leak past the reg IE in the engine compartment this code would not get thrown.
With your smell of gas I doubt it is gas cap it does seem plausible that the two are connected, but you should do something to know for sure. If it was me I would pull the plenum and inspect closely from the Evap valve all the way back to the tank like 68 suggested.
Sailor24 is offline   Reply With Quote
Old 26th July 2012, 19:00   #7
desmotesta
desmotesta's Avatar
Thanks and ARGHHHH, I JUST put the plenum back 3 weeks ago after fighting the AF and AE codes - lol (they havn't returned thankfully, but now they will do because I just said it)
Old 8th September 2012, 00:26   #8
sor118
sor118's Avatar
Garage: 2002 Carbonic Blackalicious M5
Sales Feedback: (4)
Any luck tracking this down yet Desmotesta? I have the OE code but do not smell any gas. I may try a new gas cap.
2002 Carbon Black BMW ///M5 (Black Extended Leather, Anthracite Alcantara, Titanium Trim, M-Audio with Enhanced Bass, PDC)
Conforti Shark Injected with M5Board Tune, CMS Custom Muffler Delete with OE Tips, AFE Pro Dry S air Filters, ACS rep CF Front Splitters, Flat Black Kidneys, Open brake ducts with Flat Black Brake Duct Rings, StopTech Stainless Steel Braided Lines, Shorty Clutch Stop, Lighted ZHP Knob, Custom Pure White Angel Eyes (Predator Ice housing and Rebel Tri-Star LED's driven by PowerPucks), Umnitza V4 ION License Plate Lights, Fogs color matched to HID's, Oil Pan Pad Heater for winter, 3M Clear bra on hood, Flat Black Style 65's on Nitto NT555's, Style 66's on Conti Extreme WinterContact's for the other 6 months, Interstate MTP-H9 Battery, Sybesmas remaned rearview mirror, Boomerang Espion Alert LoJack, MKIV Nav with 2010 maps.
http://www.cardomain.com/ride/2964057/1
http://www.bmwmregistry.com/detail.php?id=7570
sor118 is offline   Reply With Quote
Old 8th September 2012, 00:45   #9
desmotesta
desmotesta's Avatar
forgot to update the thread.
I can now say with confidence that the fuel smell ONLY returns when I drive in rain. I dont know if it has to do with old cabin filter or something else.
The OE code has not returned but I am planning on getting a new gas cap regardless.
B5S engine rough start, fluctuating idle and smell of fuel Burj323 ALPINABoard.com | BMW Alpina Discussion 3 16th December 2011 23:59
Fuel smell Nukeproof E39 M5 and E52 Z8 Discussion 12 24th April 2009 15:53
Fuel smell !!! Hadi E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 1st October 2006 14:31
Fuel smell when starting from cold AndyE E34 M5 Discussion 4 8th February 2005 15:20
Smell of fuel?? mikek M3 E36 3 13th April 2002 16:29
