Greetings,
So I have an 11/99 build M5. I have decided at long last to do the VANOS solenoid maintenance (replacing orings and checking solenoid function). I have noticed before that even though I have a MY2000 and 11/99 build date M5, my solenoid covers have the 4 solenoid tension set screws. So I figured the previous owner must have upgraded on work he had done at some point (although no mention of this in the limited service records I got at the dealer after purchasing the car).
Anyway, I will be following the great DIY instructions here:
VANOS Solenoid Maintenance_Full DIY and I just started. While trying to loosen the four tension screws on each side, I realize that someone must've used loctite red on them because they are STUCK. I managed to get a few of them loose, but some I am unable to turn at all. One of them I even started to strip it's so stuck! I have sprayed the screws with some WD40 and am letting that set in now. I'd really rather not have to put a torch to it because of the solenoids that live just behind the cover.
I would like get some input on this issue:
1) How many others who have done this maintenance have had extremely difficult to loosen/remove tension screws?
2) Am I right in thinking it's not normal for an 11/99 build to have the solenoid tension screws / covers with holes?
3) Also, the VANOS cover bolts are 6mm but my solenoid tension screws are 7mm. Is that normal?
Thanks for the input!
