11th July 2012, 07:36
#2
2001 M5 Ti Silver
Any auto parts shop should be able to get you a fuel pressure gauge tool (assuming you have such shops in Qatar). Make sure it can read at least 75 psi. Tricky part might be getting the right Shrader valve adapter - the older gauges I have don't have an adapter that fits on the M5.
I suppose if the hose on the tool was long enough you could tie-wrap the gauge to the side mirror or something like that for a quick check while driving but that is pretty dangerous. If the gauge or hose got snagged in anything, there would be gasoline spraying all over the place.
You don't really need to do a driving test to do a reasonable check on the pump and regulator. You can test the pressure at idle with the vacuum hose connected to the regulator. Pressure should be about 65 psi (4.4 bar). Then disconnect the vacuum hose and confirm the pressure increases to 75 psi (5 bar).
I suppose if you think the pump output at engine high loads is low for some reason, like a plugged filter, a driving test would be useful. You can buy fuel pressure gauges designed to be mounted permanently inside the car. They require a pressure sensor installed in the fuel supply piping somewhere and electrically connected to the gauge. Connecting the pressure sensor would require some plumbing.
