Protecting your M5 Carpets: Nano Textile Sealant - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 5th July 2012, 21:12   #1
Tiauguinho
Tiauguinho's Avatar
Garage: 2001 M5 Le Mans Blue
One thing that is always a concern for me, is to have the interior as clean as possible. This is where I spend most of the time in my car and where the "experience" of driving happens.
Since preservation of the velour carpets are a concern for me (not sure for how long BMW is going to make these) and I want to make the car easier and easier to clean, it was time to invest in the new Wolf Chemicals Nano Textile Sealant.
The test subject for the product are the velour carpets of my Touring, which are identical to the M5, but have the borders in cinnamon leather.
To apply the Sealant and for it to bond to the fibres properly, it is very important for the carpets to be properly clean.
The carpets were beaten up to release as much dirt as possible from the deep pile, before getting ready to scrub everything gently with APC.
Meguiars APC dilluted to 10:1 was used together with a soft brush.
Small dirt spots on the carpets.
Rinsed the carpets properly before any cleaning.
Apply plenty of foamy APC and scrub gently, working the fibre in various directions, so the dirt can get loose.
After making sure that all the carpets are properly cleaned with APC, it was time to rinse the carpets with plenty of water.
Make sure to use the water to push the dirt away, don't just aim the water hose randomly, work your way in one direction pushing the water out.
Use your hand to push the water out of the carpet. Rinse again. Push water out. Rinse and repeat until no color dirt water comes out.
The carpets were then left to dry properly outside and moved inside the house to dry - I keep on pushing the boundaries of the patience of my girlfriend, but she is a sweetie - so they can dry properly. I gave it 48 hours at least before I did anything to the carpets, as it is important the they are very dry and with no humidity.
Before application of sealant, I gave the carpets a vacuum clean and cleaned the underside of the carpets with APC and a microfibre, since they were dirty of standing on the ground.
Here is the Nano Textile Sealant ready for action. Make sure you follow the application instructions to the letter as indicated on the bottle, these new products have very strict application guidelines, not following them will compromise their durability and protection.
Spray the sealant more or less 10cm away from the carpet.
Cover the whole area properly and let it dry for 30 minutes. Apply a second layer and let it dry. I left the carpets resting for more than 48 hours before trying out any water playing.
Here are the results, stripes are from the shades on the window.
Hydrophobic behavior, so nice to see.
Its amazing how the product functions, the water just stands on it, leaving the dust particles behind.
Two very small water droplets.
Look at the angle of attack of that water drop!
Also made a small move with my iPhone, watch it in HD. Sorry for the quality, lifting the carpet on the edges, but it shows how cool it is to see the water just gliding on top of the pile of the carpet!
Happy with the initial results and looking forward to see if the product helps reduce wear and pilling on the carpet.
But also received something nice by mail... looking forward to try this one now on the paint of the M5!
To be continued after Suspension installation on the M5 this Saturday
2001 BMW E39 M5 Le Mans Blue + Heritage Nappa Black Leather - Van Manen Headers, Stoptech ST-40 BBK. The Garage Queen.
2004 BMW E39 530i Touring M Package Individual Carbon Black + Cinnamon Nappa Leather. Smooth Daily Driver.
Tiauguinho is offline   Reply With Quote
The Following 3 Users Say Thank You to Tiauguinho For This Useful Post:
josiahg52 (5th July 2012), robo (6th July 2012), zed.inc (6th July 2012)
Old 5th July 2012, 23:22   #2
paul88
paul88's Avatar
Garage: E39 M5 Le Mans Blue
thank you
paul88 is offline   Reply With Quote
The Following User Says Thank You to paul88 For This Useful Post:
Tiauguinho (6th July 2012)
Old 5th July 2012, 23:25   #3
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (25)
How does the hydrophobic stuff reacts when you actually step on it with wet shoes? Water doesn't exactly just fall on the carpets, Tiago
Fighting Oil Threads since 2007
Diny is online now   Reply With Quote
Old 6th July 2012, 00:04   #4
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
Man you raise the bar every time! If I was within 1 tank distance from you, I'd personally drop it off for detailing twice a year. Well done!
The Following User Says Thank You to bimmerule For This Useful Post:
Old 6th July 2012, 09:48   #5
Tiauguinho
Tiauguinho's Avatar
Originally Posted by Diny View Post
How does the hydroponic stuff reacts when you actually step on it with wet shoes? Water doesn't exactly just fall on the carpets, Tiago
Hydrophobic, not hydroponic
The principle is that the product will help protect the carpet against wear and pilling. What appears to happen is that like a "Filter" is made on top of the carpet pile, the water will eventually sink in, but the dust/dirt stays on top, making it easier to clean.
I intend on testing this product to see if its any good, before I order more to apply on the carpet surface of the trunk, but for 15 Euros (used 40% of the little spray bottle for 2 layers) and from what I have seen until now, its looking promising
Will keep the thread updated as the carpets get used.
Thanks! Drop it off? Man, I already have much to do with keeping two E39s clean and running perfectly, not another one! :P
Old 6th July 2012, 11:48   #6
zed.inc
Garage: 1999 Avus Blue E39 M5, 2001 "Carbon Black" E39 M5
Great job as usual Tiago.
Water isn't usually such an issue for me. Do you have any suggestions for dust protection?
zed.inc is offline   Reply With Quote
Old 6th July 2012, 14:52   #7
Tiauguinho
Tiauguinho's Avatar
To be honest, I would try or the Wolf's Textile Sealant you see above or the Gtechniq's Smart Fabric.
But I am not sure that they would help, you can give it a try, which is exactly what I am doing when I bought the sealant and am sharing my discoveries with the community. At the cost of 15 Euros a bottle its next to nothing and certainly worth for me to give it a go.
Your future thread: Textile Sealant: The Desert Test?
Old 6th July 2012, 15:15   #8
Diny
Diny's Avatar
It's the Netherlands! Totally interchangeable
Keep us posted!
Old 7th July 2012, 07:58   #9
bimmerule
bimmerule's Avatar
Sales Feedback: (8)
I guess what I'm saying is you've got more than it takes to be a professional detailer! Nice thread, keep'em coming.
Old 7th July 2012, 09:06   #10
Sparkster
Sparkster's Avatar
Garage: E39 M5 Le Mans Blue (2001)
Love the effect, but doesn't this mean the water/spillage will run right off the mat and soak into the car carpet? Surely the idea is that the mat is absorbant?
Sparkster is offline   Reply With Quote
Taking care of your M5 Plastic Trim: Protecting with a Sealant Tiauguinho E39 M5 and E52 Z8 Discussion 28 31st May 2012 18:23
Protecting air intake from water russap5 E39 M5 and E52 Z8 Discussion 15 6th April 2011 21:38
Pictures: Individual interiour: Walknappa champagner + textile Gustav E39 M5 and E52 Z8 Discussion 10 9th September 2008 18:17
Damp Carpets?!? Stoner E39 M5 and E52 Z8 Discussion 1 13th July 2004 05:41
protecting the nose Stanley E39 M5 and E52 Z8 Discussion 6 19th May 2000 16:18
