Quick confirm of fuel pump - BMW M5 Forum and M6 Forums
Like Tree30Likes
Old 5th July 2012, 16:12   #1
JoeFromPA
Garage: 2001 Carbon Black/Caramel M5
Sales Feedback: (3)
Hi all,
Whelp, it's that time again: no start condition diagnosing!
Luckily for me, I was the beneficiary of Rao's school of hard knocks as posted here on how to diagnose these things.: Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire
Condition: Car started yesterday no problem. No lights on.
Today it cranks and cranks but doesn't start. Seems like no fuel....have a half tank of gas. No known electrical issues. So I figure classic fuel pump
Pulled the (6 week old) fuel pump relay, jumped the thick wires directly via a piece of copper wire and listened for my fuel pump to start.
No noises whatsoever.
Called up Vince at Bimmerzone (2 miles down the road) and a fuel pump will be available in approx 6 hours.
Can anyone confirm if I missed anything else obvious that I should be checking? I'm a little scattered today with work and such.
Thanks,
Joe
2001 Carbon Black on Caramel - 121k miles (4/2/2013)
JoeFromPA is offline   Reply With Quote
Old 5th July 2012, 16:32   #2
rao
Garage: Silver 540i
Did you let anybody start your car and rev it to say 4000-5000 rpm in idle when it wasn't fully warmed up as certified by a German engineer wearing a lab coat??? I sure hope not
Sounds like it is the fuel pump.
Rob
Current - 98 540i with Chevy 6.6 LS2/T-56 power - Build Thread
Old - 92 325i with Chevy 6.6 LS2/T-56 Power
Older - 95 M3 with Chevy 6.6 LS2/T-56 Power
Please read the important REVISED DISCLAIMER that applies to this post.
rao is online now   Reply With Quote
Old 5th July 2012, 18:06   #3
bibledriver
bibledriver's Avatar
Garage: 02 M5 Le Mans Blue
^^^ What he said. You try to start it when jumped, just curious.
bibledriver is offline   Reply With Quote
Old 5th July 2012, 18:55   #4
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
Only other thing to double confirm would be check the valve at the filter for pressure. Confirm there is power at the jump location. If the fuse is blown pump still won't run no matter how many wires you jump with. Last look for codes.
Sailor24 is offline   Reply With Quote
Old 5th July 2012, 20:13   #5
JoeFromPA
Sales Feedback: (3)
I'm actually going to change the filter tonight before I start on the pump. By check there for pressure do you literally mean make sure it's pressurized when I release the fitting?
(this might be an odd question, but any chance a clogged filter can cause not just fuel pump strain but actually greater build-up/heat in the relay itself....which would explain why both the relay and pump went around the same time, rather than just coincidentally?)
Hmmm, I'll check for power at the jump location. I didn't think about it earlier, but I didn't get a visible spark when I jammed the copper wire in and jumped the power switch at the relay terminal. I seem to remember either seeing or hearing the spark before, though last time it was night and I was slowly moving the wire in rather than jamming it right in there as I was now.
You mention "if fuse is blown you won't get pump to the pump relay" - can you point me towards said fuse? I didn't realize there was a seperate fuse providing power to the relay, as well as the relay itself. I thought the relay was getting power straight from the ECU.
I'll pull codes via the Evolve-R cable and laptop tonight before starting on the rest of the job.
Old 5th July 2012, 20:15   #6
JoeFromPA
Sales Feedback: (3)
No, I didn't have my wife try to start it when jumped. There was zero sound of fuel pump activity when jumped (it should've been humming non-stop) and otherwise nothing changed from a moment before, so I didn't see a need. I don't think Rao was asking for that anyway - he was making fun of my other post about how I let a friend get in the car who then proceeded to cold rev it to 4500 rpms
(which, by the way, if said friend hadn't started it it might have gotten me to a client today and then stranded me and said client in a 94 degree humid day)
Old 5th July 2012, 20:52   #7
bibledriver
As you know, I have just gone through an ordeal. I do think that causing a backup can increase the "workload" of the pump, and therefore heat and perhaps even amperage through the relay circuit. We already know these relays are weak, but yours is new. My relay was taking a LOT of draw, and didn't fail. The pump I had was drawing too much. I don't think you could fry a new relay that quickly without other things coming up, but could have put the last one over the edge. Just my thoughts.
There is a fuse in the glove box named fuel pump, #22 is the one. Also, #31 is connected along with other electronics.
Old 5th July 2012, 20:54   #8
bibledriver
Yeah, caught the joke, laughed! Just asked because some people have mentioned not hearing the pump, ever. I always hear it cycle, though. Was just curious.
Old 5th July 2012, 20:56   #9
JoeFromPA
Sales Feedback: (3)
Bible,
I'm sitting in my office right now - do you know if I can swap another similarly rated fuse into #22 and try to start? I don't have any spare fuses lying around, so unless the box comes with a variety of spare fuses in it I'm guessing I'd have to swap one from another system.
Yeah, I don't think my current relay is shot - if it was, then the fuel pump should've begun pumping when I jumped the relay terminals. But I was wondering if perhaps I had something going on causing a bit of extra draw/heat in the electrical system on the fuel relay/pump. I KNOW that this car has been run down to absolutely empty a number of times - when I picked it up from the PO, the range calculator said it had 6 miles to empty. 6! And, of course, since then I've drained it to 20-30 a number of times. So I imagine both the fuel pump and fuel filter have taken a modest beating.
The Following User Says Thank You to JoeFromPA For This Useful Post:
Byrdman17 (6th July 2012)
Old 5th July 2012, 21:01   #10
bibledriver
If it is blown, (which one) there is only one good direct option for #22, which is #32, "active seat"
DIY: Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire JoeFromPA E39 M5 and E52 Z8 Discussion 68 5th September 2012 02:25
Quick Fuel Pump / Fuel Supply Question Zen M E34 M5 Discussion 13 19th June 2012 07:25
Fuel sender/fuel filter/fuel pump/ temperature gauge jack eiler E39 M5 and E52 Z8 Discussion 6 2nd May 2012 17:08
New pre cat 02 sensors, secondary air pump, mafs, fuel pump and filter = 1 happy S2!! madyspop E39 M5 and E52 Z8 Discussion 0 12th February 2011 04:37
Kenne-Bell Boost-A-Pump Install (AKA Dinan Fuel Pump Booster #D862-7320 havasusteve03Beast E39 M5 and E52 Z8 Discussion 2 11th November 2010 05:56
