295/35-18 on rear anyone? - BMW M5 Forum and M6 Forums
Old 30th June 2012, 01:35   #1
Schtozo
Garage: 1991 e30 granitsilber metalic, 2003 M5 carbon schwartz metalic
Can i fit that size on a stock wheel? Stock suspension too. A buddy is selling 2 tires with excellent life for $125 but they are 295s. Is that too wide for the 9.5" wheel or is it ok? I need to change mine because they are 255s and thats what the wheels came with.
Please help me with this one guys.. Anyone has fit 295s?
Schtozo is offline   Reply With Quote
Old 30th June 2012, 03:01   #2
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
I've had them on 10" wheels with occasional rubbing. May be too wide for a stock wheel though.
03 M5 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C 92mm pulley, Supersprint headers and Race cats, Eisenmann Sport Exhaust, RK Autowerks/Evolve tune,
Aquamist HFS-3 water methanol injection, Rogue SSK w/ RP Synchromax fluid, fog light delete, Dinan 17mm rear sway bar,
TCD sway bar brackets, Ultimate Pedals, Euro Armrest, Hardwired V1, Angel iBrights v.2, 6000K Low beams, 70W High beams,
Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
04 M3 Jet Black/Black Nappa/6 spd
Evolve Alpha-N tune, SGT Headers, Rogue SSK, Dinan Muffler
ECB is online now   Reply With Quote
Old 30th June 2012, 04:22   #3
mmzcee
mmzcee's Avatar
Garage: TiAg E39 M5
Sales Feedback: (4)
295/35/18 on 9.5" wide rim might but pushing it, I had 295/30/19 on 19x10.5 and it was already bulging out...not to mention I was rubbing like mad given my ride height.
mmzcee is online now   Reply With Quote
Old 30th June 2012, 04:49   #4
Casparado
Casparado's Avatar
Garage: '02 E39 M5
According to Tire Rack, the minimum wheel width for nearly all 295 tires is 10", with a recommended width of 10.5". Even if you got it to fit, I would be really concerned about it separating during hard cornering. Not worth the risk IMHO.
Casparado is offline   Reply With Quote
Old 30th June 2012, 13:51   #5
turbotoaster
turbotoaster's Avatar
Garage: 2000 M5 in oxford green
im running 285 slicks on mine which someone mentioned they are the equivalent of 305 wide road tyres and they are great, so much grip, you might need to run a 5mm spacer like i did, so put the cost of that and 10 30mm wheelbolts into the equation
turbotoaster is offline   Reply With Quote
Old 30th June 2012, 20:27   #6
paul88
paul88's Avatar
Garage: E39 M5 Le Mans Blue
That will be too tall as well. I ran 295 on my 10" wheel on the supra no problem.
paul88 is online now   Reply With Quote
Old 1st July 2012, 05:49   #7
PatrickW
PatrickW's Avatar
Garage: 2003 M5 Carbon Black
I was told by the race shop that mounted my rears that I might be able to fit 295's, I wonder how much taller they are than the 275's? I've seen someone do the calculation before just can't remember it off the top of my head.
PatrickW is offline   Reply With Quote
Old 1st July 2012, 07:08   #8
Schtozo
Well, multiplying the width by the % (height) will give you the measurement of the sidewall in mm. So 275s x 35% = 96.25 and 295s x35% = 103.25 that means that a 295 tire has a sidewall thats 7cm taller than the 275s
Old 1st July 2012, 09:17   #9
servo
Garage: 2002 M5 Sterling Grey
Tire size calculator
7cm? I think you mean .7cm
servo is offline   Reply With Quote
Old 1st July 2012, 15:01   #10
Schtozo
Yes sorry i meant 7mm!!
Could I use 295/30-19 in the rear stock rims? 335xi E60 M5 and E61 M5 Touring Discussion 4 8th February 2012 14:38
295/35/ZR18 on stock rear wheel? M5girl E39 M5 and E52 Z8 Discussion 40 27th March 2009 18:26
e39 295/30/19 rear tire fitting? ballgofar E39 M5 and E52 Z8 Discussion 1 3rd January 2009 00:06
Anybody running 295's on the rear? MAC M5 E39 M5 and E52 Z8 Discussion 6 16th April 2007 19:49
295/30-19 in the rear? cidair E39 M5 and E52 Z8 Discussion 0 16th March 2003 10:27
